75 delta 88 conv(floors)
Old Jan 4, 2009 | 09:43 PM
shaunr's Avatar
I have (2) holes in the floor in the back where the back passengers feet goes. Whats a good way of repairing them? I was told rivets were a good way. Any suggestions are appreciated. Also, my conv top seems to be off track, every time it goes up, a piece of the arm sticks out the side. How would I repair that or do I have to replace the whole top?
Old Jan 4, 2009 | 10:21 PM
dan2286's Avatar
I really dont know much about bodywork, but I do know that rivets are not a good repair. The best way to do it is to cut out all of the rusted metal and weld in a patch panel. Use a butt weld, do not overlap the metal. If you overlap the metal their will be the area in between the two pieces that can hold moisture and dirt, it will eventually rust out again. Make sure you put some type of under coating or paint on the repair under the car and inside the car to keep it from rusting again.
Old Jan 17, 2009 | 09:14 PM
shaunr's Avatar
thanks for the info. i sorta though rivets wouldnt work.
Old Jan 21, 2009 | 07:17 PM
UnkleScott's Avatar
Check this site for info on the infamous GM scissor top.
http://www.convertibleparts.com/scissor.htm
Old Jan 22, 2009 | 06:16 PM
UnkleScott's Avatar
I had the same problem with mine until I got my new top installed. The piece you're talking about should be glued to the top. My had come apart and never did line up correctly. I used to stop about halfway up and pull it back inline in order to get the top up.
dpt618
Aug 27, 2013 10:13 AM
eazy
Aug 25, 2013 05:16 PM
slantflat
Mar 31, 2012 03:54 PM
oldspackrat
May 30, 2011 08:39 PM
oldspackrat
May 14, 2011 07:54 AM
