'72 Delta 88 Convertible Top switch question
Old May 22, 2020 | 08:11 PM
bjfox1970's Avatar
My top switch quit working today. It feels loose and is no longer functioning.
I pulled it apart and can't see anything that is obviously broken. Are there any guru's on the board who can possibly explain what is wrong with this thing?
I've attached a pic of the switch apart. Is anything missing?
Old May 23, 2020 | 12:27 PM
bjfox1970's Avatar
Figured it out! It appears there are two tabs on the switch lever that broke off. Drilled a hole through the lever and installed a metal pin. Reassembled and installed.
Works like new again!!
Old Jul 16, 2020 | 04:07 PM
JohnMc's Avatar
How did you get the switch out?
Old Jul 16, 2020 | 09:21 PM
rocketraider's Avatar
Oldsdruid
71-73 can be pried out from front of the dash cluster (batt disconnected!) and there should be enough wiring harness to pull out far enough to disconnect the switch. 74-75 you pull the radio trim pad off and you can then access the switch.
If you can't get a 71-73 switch out from the front of the pod it gets involved as the lower dash has to come out to access the radio brace and get the radio loose from the trim panel. Once radio is out the way the pod comes out with I think four screws.
Old Jul 7, 2021 | 03:07 PM
Blue226's Avatar
Switch repair
I am having the same issue with my switch. It will only operate in the up position. Can you tell me step by step in what you did to fix the issue please.
montvaleplace
Sep 10, 2019 04:51 AM
Cathys88
Jul 13, 2013 09:54 AM
D Appeldorn
May 28, 2012 11:54 AM
D Appeldorn
Nov 2, 2011 12:45 AM
VegasDelta
Aug 23, 2009 06:17 PM
