71-75 full size gas tanks??????
Old January 20th, 2013 | 10:19 AM
The Tin Man's Avatar
The Tin Man
Is there a co. that makes them yet? I had pin hole in mine used that stuff from eastwood and the ethanal ate it in about two months. I have two 71 royal convertable I will need tanks for.(One is my frame off that might have to be sold) Thanks
Old January 21st, 2013 | 06:07 AM
Kennybill's Avatar
I don't know of any aftermarket tanks. I pulled mine and cleaned and painted it. It was in good shape. The rubber hoses are known to crack on top of the tank making for hard starting. Wow, two 1971 Royales. There can't be many left. I know where one is. Good luck, Ken
Old January 21st, 2013 | 07:20 AM
11971four4two's Avatar
MOTORHEAD
Hi
Auto city lists tanks for 73 - 74 full size Olds. I saw you listed 71 - 75 maybe they have one that will work in your cars(s).
http://www.autocityclassic.com/index...1126&Itemid=64
Old January 21st, 2013 | 09:06 AM
jaunty75's Avatar
Yes, this is kind of weird. Places like Autozone and Rockauto show availability of new gas tanks for '73 and up full-size Oldsmobiles, but if you search their sites for '71 or '72, all you get, strangely, are tanks for the full-size wagons, which I would think there would be far less demand for.
I'm not sure what the difference is, if any, in the tanks for the '71 and '72 models versus '73 and later. It may just be a part number coding thing and the tank for the '73 really does fit the earlier models, or it may be that changes to emissions requirements over those years did mean changes to the tank, and so the '73 and later tanks really are different.
Having said this, if I needed a tank for a '71 Delta 88, I'd look very hard at what the tank in my car looks like and then look very hard at the photos of the tanks for the '73 models. If they look at all alike, I'd take a chance and get one for a '73. There might be an extra vent port or return line that you might just have to plug, but that's a small consideration when you consider the alternative, which is to not have a gas tank at all or have to try to find one from a donor car. In short, if it fits in the space and holds gas, it can likely be made to work. If it ends up not fitting or for whatever reason not working, you can return it (before you put any gas in it!).
Old January 21st, 2013 | 10:11 AM
cfhcar's Avatar
71-72 tank has different evap system than 73 up. 73 up tank has a raise area around sender about 2 inches high. 71-72 tank to top is flat. i'm wondering about putting 71-72 cutlas tank in mine? i know it is smaller but has all the right fittings i have a 71 royal 2dr, 71 plane delta 88 2dr and a 71 98 4dr
Old January 21st, 2013 | 11:44 AM
MOTORHEAD
I had these guys repair a gas tank
They guarantee the repair
http://gastankrenu.com/
California
Florida
Illinois
Indiana
Iowa
Kentucky
Maryland
Michigan
Minnesota
New Jersey
New York
Ohio
Pennsylvania
Texas
Utah
West Virginia
Canada
Newfoundland
Ontario
Quebec
World
United Kingdom
Ireland
Old January 21st, 2013 | 04:56 PM
The Tin Man
Thats a sweet link Thank you. I don't care about the evp lines. Yes I have two now Got my Dads after he passed. (he bought it new) And mine that is going into paint in a few weeks.
Old January 22nd, 2013 | 07:54 AM
MOTORHEAD
Cars with a family history are a special thing. It is cool that you have your dad's car that he purchased new. Sorry to hear that he has passed.
Good luck with the restoration on your car!
Old January 22nd, 2013 | 04:34 PM
peters73ragtop's Avatar
gas tank renu
i spend most of my time on correctcraftfan.com and some of those guys have used that company with great results also quite a few of them have done the do it yourself kit with the same good results. i will look for the kit name and get back to you .
Del70
July 17th, 2014 06:43 PM
Hal
Vista Cruiser & Wagons
October 17th, 2011 11:03 PM
Wyze
March 8th, 2010 07:07 PM
ent72olds
September 16th, 2009 05:02 PM
mryoung4815
May 28th, 2009 08:53 PM
