56 Olds steering column differences
Old Feb 10, 2021 | 10:53 PM
rket56's Avatar
Does any one know why the 1956 olds equipped with power steering had a "rag joint" in the column ? The manual steering doesn't have them. I am considering a conversion using an electric power steering pump. I then then remembered that a used power steering column I had acquired years ago had a rag joint in it. I don't see any reason unless it might be to off set any stress to the power steering box created by flex between body and frame. Any thoughts appreciated. Thanks, Chuck
Old Feb 11, 2021 | 07:06 PM
Charlie Jones's Avatar
Phantom Phixer
The manual steering gears back then incorporated the steering column and steering box as one unit .
The power steering units had a separate column and steering box connected by a "rag" joint .
I think the reason is so that the steering box could be removed easier for servicing .
Old Feb 11, 2021 | 09:25 PM
rket56's Avatar
Thanks for your input
That makes perfect sense, sometimes I overlook the obvious. Chuck
Old Feb 11, 2021 | 09:49 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I don't know about 56 but the 54 and 55 power steering did not use a rag joint. The steering shaft went all the way up to the steering wheel.
Old Feb 12, 2021 | 08:09 AM
Tedd Thompson's Avatar
Lucky for me and you we have convertibles and removing a wheel with the top down is a breeze. Sorta speak...... Tedd
Bryan Burch
Feb 11, 2021 01:07 PM
Takid455
Sep 14, 2012 06:01 AM
hialeah56
Oct 17, 2010 05:51 PM
rket56
Oct 31, 2007 05:02 PM
Retrorocket88
Dec 5, 2006 04:43 AM
