54 Olds 88 Distributor question
Old Oct 16, 2008 | 08:24 PM
Bosco1956's Avatar
I have a stock 54 Olds with a 324 & a 3 speed stick. I was given a distributor from a 58 371 #1110929 Will this work in it ?
Old Oct 16, 2008 | 10:35 PM
88 coupe's Avatar
Junior Member
It will.
Norm
Old Oct 16, 2008 | 11:18 PM
Bosco1956's Avatar
Originally Posted by 88 coupe
It will.
Norm
Thanks Norm
Old Oct 17, 2008 | 05:58 AM
If you aren't concerned about "originality" I would suggest installing a Pertronix Flamethrower kit into the distributor before installing it. These will give you better driveability and more reliability than points. They are also reasonably priced.
Old Oct 17, 2008 | 09:05 AM
redoldsman's Avatar
Proud Viet Nam Veteran
The really nice thing about Pertronix is that unless somebody takes your distributor cap off, they will never know it is not original. Then the external adjustment points on the 57 distributor is not an issue. Just put the Pertronix in and go. You might want to regap your plugs.
Old Oct 17, 2008 | 10:38 AM
Bosco1956's Avatar
Thanks Guys I have several Pertronix conversions in other cars I have and they have worked well. However I am also old school and don't think there is anything wrong with a points style ign system as long as it is in good working order. Plus they are very simple to fix. I have had one Pertronix conversion go bad and it was dead in the water so to speak.
Old Oct 17, 2008 | 09:57 PM
88 coupe's Avatar
Junior Member
........ unless somebody takes your distributor cap off, they will never know it is not original ........
No need to take the cap off.
It is obvious that the Igniter uses two wires between the distributor and the coil, while the original ignition only uses one.
Norm
chris83
Aug 18, 2012 01:47 PM
benji94
May 20, 2010 08:14 AM
B-Mann
Jun 18, 2009 06:13 AM
Bunser
Sep 7, 2008 10:17 AM
OLD SKL 69
Mar 30, 2007 07:33 PM
