51 rocket 88.
Old Apr 15, 2014 | 09:37 AM
newolds5188's Avatar
51 rocket 88.
Is it possible to install a/c in this car? Suggestions. For those 110 degree days in the desert.
Old Apr 15, 2014 | 11:31 AM
Rocketowner's Avatar
newolds5188, Yes it can be done.I have pictures of the air conditioner ,that I installed on my 1955 Olds(go to Rocketowner and look at Albums). Got the unit, compressor ,condenser ,and drier and a universal mounting plate(Chrysler) From Southern Air out of Florida.Made my brackets to line up with existing generator pulley,and used a 63" belt to pull generator,water pump, and air conditioner. 5 years after installation ,no problems, even with stock radiator never heats up past half way mark, and it cools the whole car without using the high speed on fan!
Larry
Old Apr 15, 2014 | 11:53 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Vintage Air is probably the most popular aftermarket AC. The reproduce the Mark IV underdash unit which is what I am going to put in my 54. You will probably need to convert to 12 volts since I believe all these systems are 12 volts. If you don't have power steering (was it even available) you will need to find double pulleys from a 54-56 so you will be able to run the compressor. I am assuming they will fit the 51. I may have a set later since I will be replacing the double pulleys with triple pulleys since I have power steering.
Mak
53
Nov 18, 2011 04:23 PM
<rocket powered>
Feb 8, 2005 05:05 AM
<425superrocket>
Oct 14, 2004 08:18 PM
blonzz
Sep 1, 2004 04:35 AM
Paula
Aug 10, 2003 10:22 PM
