1984 Delta 88... What hose is this?
Old Jun 28, 2017 | 01:35 PM
Wauktown847's Avatar
Wauktown847
What hose is this? I believe it is for the radiator overflow but if so where does the other end connect? Where can I buy it? I'm talking about the hose that is broken in the pic.
Old Jun 28, 2017 | 02:09 PM
Can you back up a bit on the picture? There are 2 possibilities, rad overflow tank or wiper washer tank.
Old Jun 28, 2017 | 02:38 PM
It has a pressure coupling on it Eric, so it's not a wiper reservoir line. It looks more like a refrigerant line to me from what I can see.
Old Jun 28, 2017 | 03:05 PM
I'm assuming he's talking about the line at the bottom of the white plastic tank.
Old Jun 28, 2017 | 03:18 PM
Looks more like the focus is on the insulated line to me. That's highly indicative of an AC line.
Old Jun 28, 2017 | 04:47 PM
CRUZN 66's Avatar
Olds Fever
Since his photo is not direct as to what hose he is referring, I am with Eric, I think he needs the hose from the coolant overflow tank to the radiator... Also the photo appears to be taken from the passenger side where the AC lines also run which could rule out the washer fluid tank, I say could because I am not sure exactly when the deltas started having the overflow and washer fluid tanks connected to each other, which I do believe wasn't until they went FWD...
For the OP, the hose connects to the radiator at the base of the filler neck below the cap...
Old Jun 28, 2017 | 06:52 PM
Ok, I see where you're going with this. I wasn't looking at the nub underneath the pressure line. I'd also agree it's a coolant recovery tank, so that line should go back to the radiator pressure vent by the cap. So many different types of coolant tanks to look at....
Old Jun 28, 2017 | 07:53 PM
71 delta88guy's Avatar
Best to ask the original poster to be a tad bit more specific?
Old Jun 29, 2017 | 07:49 AM
Wauktown847
I'm asking about the hose that is broken in the picture. The one connected to the radiator overflow container
Old Jun 29, 2017 | 07:57 AM
Your question was answered here.
Old Jul 11, 2017 | 06:19 PM
Wauktown847
I fixed it. Thanks all.
Old Jul 11, 2017 | 08:56 PM
CRUZN 66's Avatar
Olds Fever
Good to hear a followup to your issue and that you solved your problem...
jdana24
Jun 22, 2017 09:26 PM
deaddds
Nov 15, 2016 05:33 AM
Sampson
Mar 24, 2015 09:33 AM
Perry615
Apr 16, 2013 05:55 PM
jevancho
Oct 6, 2006 11:17 AM
