1978 / 1979 Delta 88 -- Grille and Headlight Swap?
Old Dec 6, 2023 | 10:29 PM
mapearso's Avatar
Question for the group --
Are the 78 and 79 Delta 88 Grille and Headlight Assemblies interchangeable?
I know that they are slightly different -- 78 has 4 lights and the 79 has 3 lights... But I would think that if you had everything you could swap one for the other?
Thanks in advance for the reply!!
Old Dec 7, 2023 | 05:50 AM
TRFREE's Avatar
You might be able to swap the entire header panel assembly. I do know the grilles are not interchangeable , and the headlamp doors/side marker lamps are not interchangeable. The header panel is different. The 78/79 stand-up hood ornaments were different depending on the model.
Old Dec 7, 2023 | 10:10 AM
mapearso's Avatar
Thanks. Very helpful. A friend has a 78 that got hit and can get parts off a 79... but sounds like maybe would need the whole header panel assembly and even that might not work
bigdooly
Sep 15, 2015 01:48 PM
deltaskelta
Feb 4, 2013 06:14 PM
DeltaDevil88
Apr 25, 2011 10:29 PM
84oldsDelta88
29
Apr 24, 2011 07:59 AM
OldsMotion
Nov 13, 2010 01:11 PM
