1974 Delta antenna repair
Old Jun 17, 2022 | 09:21 PM
arcflashfisher's Avatar
1975 Delta antenna repair
Does anyone know where I can find a new cable for my 1975 Delta 88 antenna mast.? Also how do you take the dumb thing a part?😡
Last edited by arcflashfisher; Jun 18, 2022 at 08:50 AM. Reason: Had wrong year in title
Old Jun 18, 2022 | 07:11 AM
rocketraider's Avatar
Oldsdruid
Power antenna? Repair procedures are in the 1974 Chassis Service Manual.
DK where you'd find the nylon drive cable but I'm told correct diameter weedeater string will work.
Old Jun 18, 2022 | 02:23 PM
cfair's Avatar
Is there any accepted way to straighten a bent metal mast? I’ve never heard of one over all the years.
Also, how could you reliably connect the weedeater nylon cable to the metal mast? Maybe melt them together with a heat gun? Press fit?
I use older model (1966 - era) power antennae, but would love to know more about servicing them. I’ve gotten in as far as the motor, but backed off before breaking anything.
Just curious
Chris
Old Jul 6, 2022 | 07:50 PM
Love1955oldsmobile's Avatar
Antenna mast straighting
Please post picture of antenna mast. Is it dented or just curved?
Old Jul 18, 2022 | 06:09 AM
I have the 1975 Oldsmobile manual and fisher body book and the only thi g it realy talks about is the electrical trouble shooting.
Old Jul 18, 2022 | 07:56 AM
You never mentioned if you need to repair the drive cable or electrical cable to the back of your radio.
Old Jul 18, 2022 | 08:34 AM
therobski's Avatar
Trimmer line will work for your cable.
Old Jul 18, 2022 | 08:35 AM
therobski's Avatar
CFAIR is correct I melted the cable to the mast with heat gun.
Old Jul 18, 2022 | 01:41 PM
I was able to take the mast apart and clean all the gunk out so the piece slide in and out freely. The antenna will move some but i think the cable may be detached inside the spool. I am not sure how to take that apart to possibly reconnect it.
Stephen0523
Nov 13, 2022 04:54 PM
Delta88Vert
Apr 25, 2015 04:27 PM
ent72olds
May 2, 2013 06:07 AM
4-Speed
Aug 23, 2010 05:52 PM
johnras@wavecable.com
Feb 29, 2008 05:38 PM
