1972 Delta 88 scissor convertible top question
Old September 10th, 2012 | 11:47 AM
1972 X code 442's Avatar
The top on my 1972 Delta 88 goes about halfway up, then stops, and then goes back down. My initial thought was that the relay was bad, but I'd like to hear if anyone else has had this happen to them and what was the fix. I believe that these tops were all electric, no hydraulics.
Old September 10th, 2012 | 12:59 PM
rocketraider's Avatar
Oldsdruid
Does the motor run when it does this or does the motor stop and the top just "drifts" back down?
I've heard of scissor tops doing many strange things, but never this.
Old September 10th, 2012 | 03:29 PM
White Spyder's Avatar
I had a similar issue. It was the relay over heating and cutting out. Replaced it and everything worked great. Search for my thread on sicissors tops for more info.
Could you dend me a photo of the bow with the ball piviots on the side frame rails. I need a shot of the piviot position while the top is up and the way the bow is attached to the top in the center.
Old September 11th, 2012 | 11:31 AM
1972 Delta 88 convertible scissor top question
It seemed like the relay to me as well. Thanks White Spyder, I'll start with that first
Old September 11th, 2012 | 11:33 AM
Send me your email address. It will have to wait until the week end as I'm crazy busy with work right now.
Old September 17th, 2012 | 11:39 AM
If you sent me your email address I did not get it. Please resend
Old September 17th, 2012 | 03:42 PM
Sent it by private message. Will do so again.
Thanks.
Old September 19th, 2012 | 11:57 AM
I cannot see it due to a spam blocker that I cannot seem to over ride. Sorry.
Old September 21st, 2012 | 06:36 AM
Henri.fuselier@roche.com
RPMRestoAndCustom
May 8th, 2013 03:25 PM
White Spyder
19
July 14th, 2012 08:38 PM
White Spyder
June 17th, 2012 01:53 PM
MDchanic
June 19th, 2011 08:48 PM
MDchanic
October 26th, 2010 01:26 PM
