1969 delta 88 feul dash unit
Old Mar 18, 2011 | 12:55 PM
D Appeldorn's Avatar
mine is not working corectly and i think it is coroded.
So if anyone does have a spare,
the unit is next to the odometer,
it is about a 1969 delta 88
thanks
Old Mar 18, 2011 | 02:06 PM
Connect your fuel sensor wire to ground with the key on and see where the needle goes. It should go to full. I would bet its not the gauge.
Old Mar 18, 2011 | 09:18 PM
2blu442's Avatar
When you say not working correctly, does the needle move? What is it doing or not doing? I agree, I've seen more problems from a bad ground or sending unit than a bad gauge. But if it is the gauge I may have an extra one. I know I've got one from a 1968 if that is the same as 1969. The Cutlass shared the same from 1968-69 but don't know about the full sized cars. John
Old Mar 19, 2011 | 12:35 AM
it shows how much is in it so it works, but it also goes from left to tight now and than.
From deadpoint to exeed full point?
not constant, thought i repaired it with cleaning the back of the feulgauge.
and i tried it with the contact key on, and saw that if i mounted it back i must press more on one side to have te feul gauge work propperly.
So if one of you guy's have one, than i can try if this solve the problem.
I cleaned all the ground kabels form tank till dash, and hoping that it is not the back printplate.
I gonna trie your advice to ground the sensor kabel,
i shall make a picture of it.
our wetherguy promised nice sunny wether, so il take her out for a spin today.
Old Mar 28, 2011 | 10:05 AM
i just have made some pics.
double checked the wirering and can not vind any problem.
cleaned all of it.
So if anyone have a spare, and willing to sell.
Uploaded with ImageShack.us
I tried to put the needle back on it at first time, but it gives me constant unaccurat readings.
Old Mar 29, 2011 | 11:16 AM
was it the same? or totaly differend?
outlawspeeder
Mar 17, 2014 05:04 PM
StickW31
Nov 4, 2013 10:05 AM
golds56
Nov 19, 2011 07:12 PM
D Appeldorn
Jul 5, 2011 11:18 AM
