1969 Delta 88 Axle code RA
Old Jan 14, 2022 | 01:40 PM
1969 88 Convertible's Avatar
According to the factory build sheet, RA is listed as the axle code. What does that translate to as far as ratio?
Old Jan 14, 2022 | 02:06 PM
RA is 2.78:1 open rear, and it's the 8.5" Type O axle (same as used in the A-body cars except for the width) as opposed to the 9.3" Type O used on most full size cars. The 8.5 was used in the 350 powered Delta 88s only.
Old Jan 14, 2022 | 05:58 PM
Appreciate response Joe.
I have the 350, so it's the smaller diff as you described. I know of a 1968 delta 88 4 Dr. W/455 2bbl. For sale. Assume that the rear axel would interchange with mine and be a better option to upgrade, as I am considering upgrading to posi and possibly
changing gearing to make the car quicker off the line. I recently purchased a 69 Toronado engine, which will eventually end up in this car.
Old Jan 14, 2022 | 06:02 PM
Yes the axles interchange, however posi units and gear sets for the 9.3 are unobtanium. The 8.5 actually has marginally better aftermarket support since it's the same differential used in the Cutlass line, however even that isn't saying much.
Old Jan 16, 2022 | 04:45 AM
Sami's Avatar
It took nearly 3 years to find one when I was looking rear axle with posi for my -68 Delta 88. Finally I found one that was taken from -68 or 69 390 HP CHP version. However it's still 3.08:1, but works fine with upgraded 455 and TH400.
R. Sami
Zachb92
Drivetrain/Differentials
Mar 31, 2019 08:45 AM
sammy
Jan 10, 2016 12:32 PM
stevengerard
Sep 12, 2013 04:27 PM
AZ455
May 3, 2012 07:49 AM
JOHNNY
Aug 6, 2006 07:21 PM
