1964 Dynamic 88
Old Apr 11, 2019 | 07:51 PM
Nikojoe's Avatar
1964 Dynamic 88 front drums
I just bought a 1964 Dynamic 88. Body is rough, but drivetrain is fair. Has a growing list of attention, and brakes are top on the list. Rear drums seems to be coming off quite easily. Front drums, not so easily.
Any help is appreciated.
Regards
Old Apr 12, 2019 | 06:24 AM
Ozzie's Avatar
Regards
I don't have a 1964, so it would be best to hear from someone who does; but on some other ones it's easiest to remove the front drums with the hubs.
Old Apr 12, 2019 | 07:54 AM
Nikojoe's Avatar
1964 Dynamic 88
I able to get rear drums off. Front drums are not as easy to remove.
Regards
Old Apr 12, 2019 | 08:45 AM
OK. Read the factory service manual.
Once you do, you will find that the drums are retained to the hubs with the pressed-in wheel studs. You have to remove the spindle nut and pull the hub and drum off as a unit. If you need to replace the drum on the hub, you need to press out the wheel studs to separate the two. Once the hub and drum assembly is off, you want to re-grease the wheel bearings and replace the grease seal also.
Old Apr 12, 2019 | 08:52 AM
I merged your two identical threads. It is neither necessary nor in your best interest to post the same question in multiple threads. Keeping all responses in a single thread allows incorrect answers to be caught and corrected more quickly.
Old Apr 12, 2019 | 11:09 AM
Nikojoe's Avatar
Thanks for the info regarding front brake drums. I will remove the entire assembly and go from there.
My apologies on posting twice. I discovered that I made a mistake posting in the wrong category.
jpatfarrell
Brakes/Hydraulic Systems
26
Dec 4, 2018 03:41 PM
Toocool
Feb 5, 2018 05:41 PM
setzman
Aug 10, 2017 12:46 PM
72oldspa
Apr 8, 2014 11:13 AM
1969cutlazz
21
Jan 7, 2013 05:08 AM
