1963 S88 Antenna Assy.
Old Jul 22, 2023 | 06:05 PM
68corvette's Avatar
I am looking for photos and/or a rear mount non power antenna assembly for my vehicle. I cannot find any photos of a rear mount, let alone find a complete assembly. If I were to see what it looks like, I may be able to use another "B" body antenna assy. and make it all work.
Old Jul 22, 2023 | 07:09 PM
There are no photos because there was no factory rear mount antenna on these cars. The power antenna was rear-mounted, but the fixed antenna was not.
Sorry for the bad info. See below.
Old Jul 22, 2023 | 07:12 PM
rocketraider's Avatar
Oldsdruid
Due to interference with the evaporator, all factory airconditioned cars had the antenna on right rear fender, power or not.
Old Jul 22, 2023 | 07:22 PM
Thanks Glenn. I did not know that. With that information, Google Images is your friend.
Old Jul 22, 2023 | 08:56 PM
68corvette's Avatar
Old Jul 22, 2023 | 09:02 PM
68corvette's Avatar
That is good info since I do have an a/c car, so it explains the antenna placement. The next question is, is there a rear mount antenna out there anywhere or can I use a wildcat ( B body) antenna with a Catalina aerial? The pic supplied is good but not enough zoom to check out bezel or angle of aerial
Old Jul 22, 2023 | 09:42 PM
Oldsdruid
The AC antenna location is common to all 61-64 GM B body cars. Chevrolet and Pontiac rear antennas were mounted at about 45° angle. Olds and I think Buick used vertical antennas.
To get the antenna angle right, you'll need either an antenna with a universal base or one that has the correct base for the Olds quarter panel.
dave marki
Oct 6, 2015 05:55 AM
Delta88conv455
Aug 24, 2013 02:51 PM
4-Speed
Aug 23, 2010 05:52 PM
68Tom
Sep 25, 2009 02:14 PM
