1956 Olds replacement battery
Old May 14, 2022 | 09:34 PM
rket56's Avatar
In 2013, when I got ready to start up the Olds after years of working on it, I searched for a replacement battery. I found an online posting that suggested a tractor battery sold at Farm and Fleet was very close in size to the original battery. It was an Excide commercial, 30-H series. I did have to alter the top carrier to make it about ½ inch longer, but otherwise a good fit. I put a piece of ¼ inch plywood painted black, to fill the “step” in the lower carrier so I didn’t have to modify the lower carrier.
This spring it was past time to put in a new battery and I found the 30-H series almost impossible to get. I did find a replacement at Batteries +. The Duracell Ultra Flooded SL31PA is the same size as the 30H but has the battery posts set about 1.5 inches closer to the fender. This is a sealed unit that has 950 Cold Crank Amps. Hope this helps anyone looking for a replacement battery for a ’56. Chuck
Old May 15, 2022 | 04:14 PM
ignachuck's Avatar
Frank Ignachuck
Great info, Chuck. Thanks!
A couple of years ago I bought a NAPA DC Marine Group 31 Battery for my '56. As you know, the Group 31 is pretty close to the Group 60 battery size that was original to the car. I found a vintage plastic KANT-KER-RODE battery hold down that fits perfectly, and uses the original holes to attach to the fender. KANT-KER-RODE was made near me in Clinton Ma. so I had to buy it!!
Old May 19, 2022 | 07:38 PM
vintagepne's Avatar
You might also try Battery Central Mall, https://batterycentralmall.com
Old May 19, 2022 | 09:00 PM
tnswt's Avatar
'70 4-Speed W Machine
I put in for one of those Battery Central Mall batteries November 21, 2021, and still don't have possession of it.
Old May 20, 2022 | 06:14 AM
The_German's Avatar
I bought this one, this is the real one:
https://batterycentralmall.com/produ...ery-1954-1965/
Old May 20, 2022 | 09:15 AM
tnswt's Avatar
Not to be disappointing, but buying is one thing, receiving the battery is something else entirely
Old May 20, 2022 | 09:19 AM
The_German's Avatar
I got mine, no problems... Yes, I waited 4 months or so, that is why I replaced the battery before the old one passed away...
Old May 20, 2022 | 06:52 PM
Tedd Thompson's Avatar
Remove the yellow caps replace them on your new battery if your new one doesn't come in yellow. Only matters if you show your car in a points type show, otherwise disregard this post.
stevenwham
May 16, 2022 05:38 PM
Jon442
May 10, 2021 07:31 AM
Neil Morrison
Feb 28, 2020 06:35 PM
DFitz
Dec 12, 2019 09:13 AM
Oldssupreme
Nov 3, 2019 03:34 AM
