1956 olds front suspension help needed
Old Jun 24, 2012 | 10:07 PM
cobalt's Avatar
1956 oldsmobile
Im doing the front suspension on my 1956 oldsmobile..im replacing eveything in the photos that are marked with the letter A...just wondering if i can just replace the rubber bushings on the ones i marked with the letter B...or do i have to replace the metal shaft too..and where is the cheapest place to order these items..thank shane
Old Jun 27, 2012 | 05:47 AM
Rocket331's Avatar
The upper & lower pivot pins you have marked 'B' just have grease seals in in them. There are no bushings. If they aren't torn, hard , or missing you can leave them alone. But, they are easy to replace and are available from Fusick for $2 each. Because the pivot pins are used to adjust caster & camber, you'll need a frontend alignment after replacing them.
Old Jun 27, 2012 | 03:05 PM
cobalt's Avatar
1956 oldsmobile
thanks
thanks rocket331...learning from the pro's...love it..its making doing this front end easyer and cheaper...thanks
dprestia
Suspension & Handling
17
Oct 20, 2014 07:34 PM
cobalt
Jan 23, 2013 10:55 PM
cobalt
Aug 16, 2012 08:05 PM
cobalt
Jun 25, 2012 08:39 PM
56Super88
Nov 7, 2011 12:38 PM
