1955 holiday trunk trim
Hi guys after having a look around on here and on the net in general I noticed a lot of 55's have a different trunk handle to mine can anyone tell me why please
Cheers Charlie
Cheers Charlie
After Researching Some ,And Picking My Old Brain Lots,I Believe This Emblem May Be Off A 1957 "88 Series".A '55 Or'56 "98" Olds Had The Long Trim Piece That Attached To The Top Center Of The Trim That Is Pictured , as I Remember The Emblem On The '57's Was Much Wider Than On PreviousYear Models. Correct Me If I Am Wrong . LARRY
Not related to your trim question but do your exhaust pipes lay across the bottom of your gas tank as it looks like on the photo? I would think they would be very close to the ground and could cause a scrape and bend issue on some gas station exit and entries... Just a curious observation...Tedd
Charlie
I can remember back in the day seeing more than one 54-56 Olds with tailpipes just like the ones Cosmic has. Then when I started with the 54 I really wondered about it. With the power steering on my 54 it is pretty near impossible to put duals on it. The X member on the frame would have to be cut but I think it would get by the booster tank. I will look closer when I put the tread vac back on. Mine are fake duals with one Smitty and the tailpipe split in front of the gas tank. I know that duals were available in 56. I think they were on 98's and had special extensions that bolted to the bumper. Fusick has them and I gave brief thought to using them on my 54.
Mine are true duels but it is not an easy conversion with many twist and turns and a couple holes punched in the X frame. 56's could be had with duels because they moved the booster to the firewall and this open up a passage to the rear....Tedd
Hi
Yes the system on my 55 is a complete dual system front to back and the tail pipes do run under the gas tank, the booster is in its original location and the pipes seem to have adequate ground clearance. I will take a couple of pictures at the weekend and post them as it is undoubtedly easier to see rather than explain
Charlie
Charlie
I Admit Defeat Concerning The Emblem In Question On The Trunk Of The '55 Pictured,It Is Off A 1956 Super 88,I Had Looked At A '56 88 And It Did Not Have The Short Pieces Going above Or Below The Circle. Larry
I must admit I don't know a lot about Oldsmobiles but I really struggled (& failed) to identify the boot trim it doesn't seem to be very common
shamusj
April 7th, 2018 08:10 AM
allwood2006
November 12th, 2009 11:52 AM
