Rear end options?
Old Sep 16, 2013 | 04:25 PM
Fummins's Avatar
Rear end options?
Im near ready to modify/swap out the rear end in my 1969 Cutlass, car was born with a peg leg and gears that dont suit my driving style (2.73) or something like that, dont recall exactly anymore. Anyhow im wanting a posi and something in the 3.55 to 3.73 ratio range. Seems i recall modifying the existing rear end was cost prohibitive? Any options for a direct bolt in from another Olds or? Im running a BB and M21 close ratio drivetrain. Thanks for the help in advance.
Old Sep 16, 2013 | 06:43 PM
oldsmobiledave's Avatar
More info
Before we give advice you need to clarify which rear end you have now. It will be a type o 12 bolt, a type c 12 bolt or one of a variety of 10 bolts. Which do you have?
Old Sep 16, 2013 | 07:32 PM
Fummins's Avatar
I honestly dont know Dave, what is the procedure for correct identification? Thanks
Old Sep 17, 2013 | 06:07 AM
monzaz's Avatar
I D Differentials
www.jdrace.com has a I D Differential or you can snap a few shots of the rear cover that will help us ID the rear. Jim
J D
Old Sep 18, 2013 | 09:24 AM
Fummins's Avatar
J D
Thanks Guys, will check it this afternoon.
Old Sep 19, 2013 | 01:46 PM
Fummins's Avatar
Visual inspection showed no id tag, diff cover has 12 bolts. The car was born in the US. Any help?
Old Sep 19, 2013 | 08:11 PM
507OLDS's Avatar
It should be the 12-bolt O-axle. Gears for these are about non-existent right now. I would build a 71-72 8.5" 10-bolt,or a 12-bolt Chevy. If you can't find anything out your way,I have both styles that I can build to suit.
Jul 5, 2012 09:34 AM
Doug in SD
Drivetrain/Differentials
Jul 8, 2011 06:58 AM
1965cutlassragtop
22
Jun 8, 2011 08:11 PM
f-85
15
Oct 8, 2009 07:30 AM
Topless72
Feb 2, 2008 08:37 PM
