Axle Retention
Axle Retention
I'm swapping the brakes out of my BOP 8.2 and need to remove the axles to do this. I just found that these are flanged axle retention so no C clips. Does that mean I just need to slide hammer the axles out? Thanks in advance.
George
George
If you need to remove backing plate then the axles must come out otherwise brakes/wheel cyls can be done without pulling axles. Axle bolts/nuts need to be removed then they should come out with not much force. A slide hammer may be extreme but could be required.
Del70
May 16, 2011 11:32 AM
cutlasssupreme71
Drivetrain/Differentials
Feb 22, 2011 11:40 AM
