Rear gear suggestions
Old Feb 23, 2011 | 09:33 AM
Jacoz70442's Avatar
I've got a '70 455 442 convertible that I am restoring as a driver. The engine is a mild rebuild .040 over with very mild cam. I plan on keeping it as stock as possible to run through the TH400 trans. My question is, what suggestions on rear ends? I am definitely fitting with posi, and leaning 3.42's, but open as there's a lot of expertise here. Thanks for the input!
Old Feb 23, 2011 | 10:01 AM
Run to Rund's Avatar
With small diameter tires (14") and a lot of highway driving, 3.42. With taller tires or mostly town cruising, 3.91.
Old Feb 23, 2011 | 03:26 PM
BlackGold's Avatar
It also depends on your definition of "highway driving." If you seldom get above 60 mph, the 3.42 gears will be great. But if you live out west and/or love to cruise at 75 - 80 mph, you might want to consider 3.08 to 3.23.
Old Feb 23, 2011 | 06:30 PM
monzaz's Avatar
choice
I agree with this selection and reasoning.
I second this vote.
WHAT rear do you have as this could become an issue in finding a GEAR RATIO you need. Jim
10 bolt 8.2 olds/pontiac
12 bolt 'o' type
10 bolt 8.5
Other?
Old Feb 24, 2011 | 06:16 AM
507OLDS's Avatar
The car should have a 12-bolt O-axle,unless it has been changed.A lot can happenm in 40yrs.If it still has the original 12-bolt O-axle in it,it should have a decent gear in it already,like a 3:08 or 3:23.If that is the truth,then maybe all you need is a posi carrier.
Old Feb 24, 2011 | 09:13 AM
Jacoz70442's Avatar
Great, that's what I'm looking for here. Truth is, I probably will be driving around town with an trip out once in a while. I live in WI, so only parts of the year on highways and limited at that. I need to check my current axle to see, but sure it's not posi. I will not be tracking this thing, so not worried about drag times, etc. Suggestions on where to pick up a good posi carrier?
Old Feb 24, 2011 | 09:15 AM
oldzy's Avatar
3.42 4u
Old Feb 24, 2011 | 10:29 AM
507OLDS's Avatar
Jim(monzaz) has some carriers available now.I'm all out at the moment.If you have a 3:08 or 3:23 in there now,then I would just leave it,and add a posi,especially if you have a 3:23 because there won't be much difference between the 3:23 & the 3:42,to justify buying new gears.Look at the 2-letter code on the backside of the passenger side axle tube,and let us know what it is.It might be upside-down,depending on when the car was built.
Old Feb 24, 2011 | 11:29 AM
Jacoz70442's Avatar
Thanks guys, this is really very helpful info. It's amazing how much you can read up on these, but when it comes down to it I trust the guys who have the cars and build'em. I'll check the code and get back here. May save me some $, and I most certainly will need it in other areas of the car.
Old Feb 24, 2011 | 12:40 PM
Aceshigh's Avatar
Price out a posi carrier for that Oldsmobile "O" rear end. Might realize it's really pricey for used stuff .
507OLDS seems to be the resident expert rear end guy here, and Monzaz.
THere's a thread that shows the codes on your right passenger side axle tube so you can see what gearing it came with from the factory.
71Cutlass-S
Drivetrain/Differentials
21
May 3, 2020 06:39 AM
navvet
Suspension & Handling
Oct 4, 2013 01:57 PM
jeffu231
Nov 14, 2012 04:33 PM
drjr56
Sep 9, 2012 08:05 PM
Aceshigh
Brakes/Hydraulic Systems
Jun 24, 2010 09:05 AM
