Differential question
Old May 24, 2020 | 07:24 PM
Platinum69's Avatar
Can someone tell me what size carrier this rearend has? I want to buy a posi carrier for it. Currently has 3:08 gears. It's a 69 442.
Old May 24, 2020 | 07:47 PM
BackInTheGame's Avatar
You can't tell by looking at the outside. There are four different limited slip carriers that could go in that housing. BUT, if you are certain it is a 3.08:1 gear set, it has to be a 671 carrier. You can find info about such at https://supercarsunlimited.com/info/...id/diff_id.htm.
p.s. it looks like you better attach your gas tank ground strap.
Old May 24, 2020 | 08:25 PM
That is an O-Type rearend and as stated above there are multiple carriers depending upon the gear ratio. It is a unique Oldsmobile-only 8.5” unit that is not interchangeable with the common 8.5” corporate rears.
These rears don’t have a lot of aftermarket support so don’t expect to find parts at Summit, Jegs, etc. The good thing is someone figured out how to machine the Ford 8.8 posi carrier for the O-Type 2.93-3.23 gear sets and those are available from multiple sources. SupercarsUnlimited has parts, as does monzaz on this site - he has a differential business and can likely get what you need.
Old May 25, 2020 | 10:14 AM
rcorrigan5's Avatar
Randy C.
I changed my '69 3.23:1 "O" type differential from open to limited slip through SupercarsUnlimited.com. As I recall, the owner there (Greg Rollin; he will answer the phone (503-641-1442) and talk with you about it; he's very Oldsmobile-knowledgeable) has conversions for the 3.08:1 "O" type as well. Expect it to cost around $1000 for all the parts.
Randy C.
Old May 25, 2020 | 12:55 PM
Platinum69's Avatar
p.s. it looks like you better attach your gas tank ground strap. [/QUOTE]
That's an old picture. It is currently attached and works fine. Thanks
88hurstolds
Aug 17, 2018 03:53 PM
hueveaj
Jul 16, 2016 03:07 AM
kevdog442
Drivetrain/Differentials
Apr 24, 2016 05:50 PM
wildcatmom
Oct 27, 2013 08:56 AM
4fortwo
Nov 22, 2008 10:02 AM
