70. Cutlass rearend
Old Jul 24, 2019 | 09:54 AM
Felipe4's Avatar
70olds
70. Cutlass rearend
Ok so I have a 70 cutlass 10 bolt limited slip rearend. driveline spins rear wheels will not move no broken spider gears. Ring and pinion spins when in drive. car still rolls in park any chance I broke a rear axel
Old Jul 24, 2019 | 10:29 AM
That sounds like the only possibility. To find the side with a broken axle shaft, try jacking the rear wheels up one at a time, rotate the wheel, and see if the carrier moves or not.
Old Jul 24, 2019 | 11:29 AM
Felipe4's Avatar
70olds
Okay thanks I will give that a try and let you know
Old Jul 31, 2019 | 07:54 PM
Felipe4's Avatar
70olds
Pulled axels out today all splines are fine bearings and seals could it be transmission
Old Jul 31, 2019 | 09:24 PM
If the driveshaft turns but the wheels do not, there's something wrong in the differential. Pull the cover and look for broken teeth on the ring or pinion gears, broken cross shaft, or broken side gears.
Old Jul 31, 2019 | 09:54 PM
Felipe4's Avatar
70olds
Old Jul 31, 2019 | 09:56 PM
Felipe4's Avatar
70olds
Old Jul 31, 2019 | 09:57 PM
Felipe4's Avatar
70olds
Old Aug 1, 2019 | 10:32 AM
monzaz's Avatar
ALL that STILL should not cause the car not to move. Weird. You put the car in drive and it does not move?
Drive shaft spins, Yes? And these are the pictures of the rear? Look at all the ring teeth to be sure your not missing a BIG chunk.... see if the pinion shaft broke in 2 ...it could just be spinning the shaft and broke at the head?
leave the cover off and watch the gears and see what is happening when in gear forward and reverse...BE CAREFUL!!! do not get run over.... Jim
Old Aug 1, 2019 | 12:00 PM
Felipe4's Avatar
70olds
Yes it all spins can it be my transmission I have a video on youtube cutlass rear end I don't know how to upload it here
Old Aug 1, 2019 | 12:01 PM
Felipe4's Avatar
70olds
Old Aug 1, 2019 | 01:53 PM
monzaz's Avatar
rear end
Pretty weird...And if you put it on the ground it does not go?
So it looks like you put your rear breaks on and hit the gas and the carrier turns so cones are totally gone. BUT even if the cones were totally gone the car should move like a OPEN non posi diff? one wheel should default and make the car go. BUT if there is something we can not see going on in the limited slip posi unit well ...Just have to open that up.
Weird... Have to think more on this.
Old Aug 1, 2019 | 02:24 PM
Felipe4's Avatar
70olds
Ok if I open it up and keep everthing in order should it go back in fine
Old Aug 1, 2019 | 02:27 PM
Felipe4's Avatar
70olds
If you listen to the video you can hear a hum or grind. And also when I put it in park the transmission grinds
Old Aug 2, 2019 | 01:01 PM
Felipe4's Avatar
70olds
So how do I go about measuring the housing I see 8.5. And 8.2 how do I measure it I think I'm just gonna buy a new differential any suggestions on which one of those will help
Cory Kloter
Drivetrain/Differentials
Sep 4, 2019 07:10 PM
Redog
Aug 30, 2013 04:16 AM
my442conv
24
Oct 20, 2011 03:56 AM
sbFALL63
Aug 27, 2011 09:25 AM
1964Jet*88
Jul 21, 2008 05:26 PM
