Is this a correct method to determine rear axle ratio on Rallye 350 4spd?
Old Feb 23, 2019 | 03:06 PM
Texas442's Avatar
1971 442 conv
The car is a 1970 Rallye 350 4 speed. Today, we wanted to verify the rear end ratio. The rear end has the posi tag. I did not want to scrape off the undercoating to find the axle code. Here is what we did:
We secured the car on Jack Stands
We turned the passenger rear tire forward. We noticed the driver side turned forward as well.
We turned the passenger rear tire backward. We noticed the driver side turned backward as well.
We marked the drive shaft with a piece of tape
We marked the passenger rear tire with a piece of tape
We turned the passenger rear tire ONE FULL turn forward while counting the number of revolution of the drive shaft.
We counted just under just under 4 drive shaft turns for 1 tire revolution (~3.9 turns)
Did we do this correctly? So does that mean we have somewhere around a 3:91 gear? If not, what should we have done differently? Thanks
Old Feb 23, 2019 | 03:17 PM
Oldsmaniac's Avatar
You did it right!
Old Feb 23, 2019 | 03:25 PM
monzaz's Avatar
Posi
Now Go Use that DIFF.
coltsneckbob
Drivetrain/Differentials
52
Apr 12, 2020 09:53 AM
Sampson
Mar 18, 2013 07:43 AM
Magna86
Apr 24, 2012 04:51 AM
Coltonis
Oct 27, 2009 10:15 AM
69-Sguy
Nov 19, 2007 07:56 AM
