Limited slip going rate
Old May 7th, 2018, 03:21 AM
Member
kevdog442's Avatar
Was trying to get an idea of what I should pay for a ‘68 type O rear differential with 3.42 gears and 588 posi carrier. The housing has been changed because the original was damaged. I think it’s an SA housing. Says it’s ready to run. Is there a going rate assuming gears look fine?
kevdog442 is offline
Old May 7th, 2018, 04:53 AM
72 Olds CS
RetroRanger's Avatar
Used good to go in decent shape 800-1000
I had my 10 bolt rebuilt w new bearings and changed gear to 3:42 and added posi for about $1400
RetroRanger is offline
Old May 7th, 2018, 10:00 AM
Rog
Rog's Avatar
I got a brand new anti spin carrier assembly with new 342 ring and pinion set and the inst stall kit for 1,195 inc. shipping my housing was a se typ o. from supercars unlimited they were great to work with. every thing went just as it should have
Rog is offline
Old May 7th, 2018, 10:23 AM
MOTORHEAD
11971four4two's Avatar
Around here they are hard to find. With rusty axle tubes and not too messed with $1000 or so for a used one. Rebuilt and , or nice $1650 and up , the last one I sold $2500..
11971four4two is offline
Old May 7th, 2018, 07:39 PM
Member
kevdog442's Avatar
He’s asking $900.
Old May 8th, 2018, 02:21 PM
MOTORHEAD
Originally Posted by kevdog442
He’s asking $900.
That is not a crazy price these days. Check it out if close by and maybe he would take less $$ ?? Good Luck!
But as Rog stated almost same $$$ for new posi and gears you could put in axle you already have
Old May 9th, 2018, 06:02 PM
Member
kevdog442's Avatar
Hard to pass up when it’s literally across the street. I passed up on it a couple years ago when he tried to trade me for a $600 ATV, but he told me it was a 2.73. I’m kicking myself for telling him the TM code was a lower gear.
He’s a Chevy guy and when he got it it was under a Camaro. The TM housing had been hacked up with new brackets to fit.
Old May 9th, 2018, 06:27 PM
MOTORHEAD
IF your car has the same 28 spline axle
With a good housing you could add the gears / posi
I would not pay more than $400 for that scene
Just saying
hope you find what makes you happy
Old May 10th, 2018, 03:39 AM
Member
kevdog442's Avatar
I’m happy regardless
Old May 10th, 2018, 04:48 PM
MOTORHEAD
:d:d
MDchanic
Suspension & Handling
June 9th, 2016 05:55 PM
auto_editor
Drivetrain/Differentials
March 11th, 2014 08:32 AM
Nailhead 88
June 20th, 2008 04:05 PM
68rocketred
April 25th, 2008 06:38 PM
Quick Reply: Limited slip going rate
