One Piece Bearing/Seal Pros and Cons
Regarding the '72 Cutlass 8.5 rear end, are there any pros/cons of the one piece bearing/seal combo over the bearing and seal being separate?
Thanks, Mike
Thanks, Mike
I am unfamiliar with the one piece design. The two piece design has two separate parts that are pressed on, then have a lock ring pressed on as well to help keep everything in place. I had a wheel bearing come loose once, so I would want to be sure the one piece design holds on as well as the separate pieces.
olds 307 and 403
January 14th, 2015 06:24 PM
