wondering if this was from a 1967 10 bolt Posi
Old Jun 22, 2022 | 01:41 PM
ggoudas's Avatar
I blew up a 10 bolt that only burned one wheel about 25 years ago. I came across a piece of the end cap that had a number on it.
Can this part be associated with a posi unit?
Old Jun 22, 2022 | 03:44 PM
monzaz's Avatar
NO will be for posi or non posi housing... WILL have nothing to do with a posi unit it self, that is a Bearing caps and it is totally useless with out its cast center section housing that the tubes are pressed into. THOSE are Pontiac 10 bolt 8.2 bearing caps from 1966 - 1972 era
Old Jun 22, 2022 | 04:54 PM
ggoudas's Avatar
Interesting thanks i guess i feel better that i tossed that 10 bolt . It was about 30 years ago Thanks for all free knowledge you and others give on this site.
Old Jun 23, 2022 | 05:20 AM
monzaz's Avatar
Yep, You can toss those too if the housing is long gone. I HAVE seen people install different caps in different housings. AND of coarse many will say it works fine...AND it may... But they really are a machine item like a MAIN in a motor and need to be kept with their original mated area in the housing of that particular rear end housing.
Jim
JD
Bob Kelso
Jan 29, 2021 02:31 PM
djsoldzparrts
Jan 22, 2021 01:02 PM
Bob Kelso
Dec 4, 2020 02:29 PM
