Will this fit my 69 Type "O" 12 Bolt ?
My car is 69 Cutlass with Single Track Type "O" - No show car status
Looking to economically upgrade to posi for my Cutlass, the 69 Cutlass now has a motor being from a 1970 Olds 455 with Muncie M20
Searched & cleaned (like 5 times) but NO axle code to be found
So I wanted to check the ratio
Jacked up the rear end and rotated just one non posi tire 2 times -
and the drive shaft rotated 6 1/4 times
So my rear ratio is 3.23 (?) YES ?
I read here that the "O" type 3.23 is a 28 spline set up
and I found this posi unit that should be a direct fit in as a replacement to give me posi
Here is the 2 units
https://www.ebay.com/itm/68-72-Oldsm...ry!01985!US!-1
https://www.ebay.com/itm/68-72-Oldsm...oAAOSwO7pcad6t
Your comments / suggestions / recommendations much appreciated
C
Here is the 2 units
C
Recheck your count. A 3.23 would have been about 6 1/2 turns. A 3.08 would have been about 6 1/8 turns. I'm betting it's the latter. Those posi units should work if the vendor has the application correct. Of course, the Type O axles were made from 1966-1970, so the fact that they say 68-72 would indicate that they are less than fully versed on the intricacies of Olds rear axles.
yes
My error
I posted wrong from doing it too many times
my 1st post should have said 4 tire rotations = 6 1/4 drive shaft turns
I just redid it
2 tire rotations = 3 1/8 on the driveshaft
so thats a 3.08 and still a 28 spline ?
I'd be happy with either 3.08 or 3.23 and his web page says either is a direct replacement using my ring & pinion (?) Yes ?
How sturdy is my existing unit ? Will my housing and or the posi I could install take abuse ?
Or should I just seek a complete used Corporate 12 Bolt posi "A body" from 68-72 ?
I agree with his mis posted info about years - I saw that too
I'm going to call him tomorrow (Rons Machining Service) and ask a lot of questions ...
800 694-3098
Thx for you input
His Web Page does say
[font]Application: 1968-1972 Oldsmobile Cutlass & 442 GM 8.5" "O" Axle[/font]
[font]1- GM 8.5" Olds Clutch type Posi LSD (28 Spline)[/font]
[font]1- Bottle Posi Additive[/font]
My error
I just redid it
800 694-3098
Thx for you input
- [font]Cover Bolts: 12[/font]
- [font]Ring Gear Bolts: 10[/font]
- [font]Axle Splines: 28 (must check)[/font]
- [font]Pinion Splines: 27[/font]
- [font]Compatible Gear Ratios: (Factory 3.08-3.23) (Richmond 3.42-3.90)[/font]
Yes, those aftermarket carriers are made to fit the factory 3.08-3.23 gears.
My understanding is the O-Type is essentially as strong as the later 8.5" corporate 10 bolt. What are your plans for it, as in how hard do you plan to drive with it? The one under my car has survived a lot of spirited use over the past 35+ years.
I don't know what a "Corporate 12 Bolt posi "A body"" rear is. I am familiar with Chevy 12 bolts and corporate 10 bolts.
Again my error about Corporate (new to me stuff) - thanks for correction
My use is just local use, no long trips or 1/4 mile track, and leaving some spirited black marks here or there,
so the 1969 Type "O" 12 bolt in mine converted to posi should be strong enough -
and there are some 1970 and up Corporate 10 bolts posi A body complete units in my area for sale as well, as well as the more expensive 68-72 A body 12 bolt (Chevy) posi's as well
so NOW I'm seeing many choices for my rear end posi upgrade
Thank You
so I'm learning and shopping
Thx
Thank You
Thx
