What's it worth?
Old Jun 16, 2011 | 05:24 AM
CQR's Avatar
CQR
What's it worth?
I'm looking for a spare rearend for my 67. I'm looking to put together a 'turnpike cruiser' (2.41:1) rearend for road trips Not really interested in a posi. just real high gears. What should I pay for a 10 bolt? Sorry, I'm an old ford guy, and all this GM stuff is new to me. Is this a good deal? I should be able to talk him down. Looks like he has posted it for a while.
http://denver.craigslist.org/pts/2437102806.html
P.S. Also coming from a 67 Chevelle should make it a direct bolt in? correct? what other years of A bodies use the same housing?
Old Jun 17, 2011 | 05:12 AM
CQR's Avatar
CQR
Anyone? Looks like this carrier may not do what I need anyhow.?. I don't think the drop from my current 3.23's to a 3.08 will be enough of a drop for me to spend the time on a swapout.
Old Jun 17, 2011 | 05:13 AM
507OLDS's Avatar
The 66-72 Cutlass/442 have the same width rear as the 68-72 Chevelle. The 64-65 Cutlass/442 have the same width rear as the 64-67 Chevelle.
Buick & Pontiac followed suit with Oldsmobile,so the 66-72 Skylark/GS,and 66-72 Lemans/GTO have the same width rear as the 66-72 Cutlass/442.
Anything with highway gears & no posi can be had for cheap,$100.00 or less.If you get a rear from a Chevelle,it will likely have the 1310 u-joint yoke,so you would need a different u-joint to make it work.
Old Jun 17, 2011 | 05:49 AM
CQR's Avatar
CQR
Good info. Thank you.
Old Jun 17, 2011 | 12:40 PM
budgdawg's Avatar
So 507, the 12 bolt Chevy posi rear i've got under a 71 el camino will go under my 67 Cutlass with no major problems? Right width too?
Also, bought a 12 bolt Type O for $200. Its open with 2.56's. Worth it or not in your opinion?
Old Jun 18, 2011 | 10:39 PM
507OLDS's Avatar
Yes,a 68-72 12-bolt Chevy rear is the same width as a 67 Cutlass/442 rear,and will install without issue.You will only need the adapter u-joint,if the 12-bolt Chevy rear has the 1310 yoke,as most of the common ones do.
Old Jun 19, 2011 | 04:33 AM
jensenracing77's Avatar
where are you located? if you are close enough to pick it up i have a 2.73 rear end out of 72 cutlass for $50. it is the smaller rear end, not sure what size those are but it's not the 8.5. i am in indiana
Old Jun 19, 2011 | 06:00 AM
CQR's Avatar
CQR
Thanks for the offer jensenracing77. but I'm in Denver. I found one in a Grand Prix for $70 but it has 2.93. I'm really looking for 2.73 or higher. So I'll keep looking. Thanks again.
Old Jun 19, 2011 | 07:44 AM
chequenman's Avatar
Exclamation
I think other then the Yoke difference you'll find Olds Axles bolt in and the others use "C" clips in the Diff.
JWW
Jun 16, 2007 09:53 PM
lovinbeinamom
Aug 17, 2006 07:49 AM
tomeriker
Jul 9, 2006 09:00 PM
Tink
May 11, 2006 02:41 PM
linas9
Feb 23, 2006 01:10 PM
