What Rear End is in my Cutlass
Old Sep 15, 2009 | 07:20 PM
Snowdog's Avatar
How can I tell what is in my '65 Conv. with a Jetaway,
Without opening it up? Going to change gear oil soon.
Has 45,000 on it.
Old Sep 16, 2009 | 08:56 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
A 65' in Willow Springs?!
NICE!!
It's probably a 2.78:1 ratio.
You'll confirm when you change the oil.
Old Sep 17, 2009 | 04:22 AM
Snowdog's Avatar
Last cruise nite in Downers Grove
Old Sep 17, 2009 | 06:24 AM
pontiac1's Avatar
If you have a non-posi, jack up one rear wheel and count the number of turns the driveshaft makes when you turn the wheel one revolution. If it is posi you'll need to jack up both wheels. You can also clean off the right axle tube to look for the numbers. On our 64 they were on the rear near where the tube meets the carrier (cast iron part).
Old Sep 17, 2009 | 12:20 PM
svnt442's Avatar
That will only get you half way. The spider gears will cut the driveshaft revolutions in half if you only turn one wheel.
Old Sep 17, 2009 | 12:48 PM
pontiac1's Avatar
If you jack up both wheels, then spin one, the opposite wheel is going to spin couter to the one you are turning and the driveshaft will probably stay in one position. Note I did say to turn the wheel one revolution and count the number of times the driveshaft turns, not turn the driveshaft. In any case, with one wheel held, all the torque is transfered to the wheel with least resistance.
Old Sep 17, 2009 | 02:15 PM
jims2000lt's Avatar
11.52 @116
Very nice ride Snowdog.
Old Sep 17, 2009 | 03:06 PM
svnt442's Avatar
Yes and because of the spider gears the amount of revolutions that one tire will spin while the other is stationary changes to double. So if you jack up one side only to count the revolutions of the driveshaft while turning the tire one revolution you will get half of the number of turns of the driveshaft that you would get if both tires were turned.
Old Sep 17, 2009 | 05:39 PM
Snowdog's Avatar
What #'s am I looking for?
Old Sep 18, 2009 | 08:31 AM
pontiac1's Avatar
They vary from year to year. On our 64 it has "P 3.08". Of course, this will be the ratio installed at the factory, and not necessarily what someone else may have installed. You can always pull the cover and check the numbers on the ring gear. They will show ring gear teeth and pinion teeth count. In our case it's 40 13. Then you divide the ring gear count by the pinion count. There is a whole section on differentials in the Tech portion of this site (see the top bar).
rcdynamic88
Drivetrain/Differentials
Apr 7, 2015 11:21 AM
350TurBRO
Sep 12, 2014 11:52 AM
MDchanic
31
Aug 12, 2012 04:24 AM
<George>
Jul 12, 2004 11:00 AM
crank.it
Apr 30, 2003 07:01 AM
