what rear axle on my 56 Super 88?
Old Jun 18, 2011 | 03:43 AM
giaguaro's Avatar
i was wondering what axle i have.
It has no bolts.
Thanks for helping!
Old Jun 18, 2011 | 04:01 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Copied from another forum:
Codes for 1956 ratios as follows; Code 6 is 3.64:1, code 8 is 3.42:1, code 9 is 3.23:1 and code 0 is 3.08:1.
Hope this helps.
Here's the original post: http://www.jalopyjournal.com/forum/s...d.php?t=105783
Old Apr 2, 2013 | 12:33 AM
giaguaro's Avatar
here i am again.
Well what i dont understand is if i have a Dana or what manufacturer my rear axle is built
Old Apr 2, 2013 | 07:28 AM
monzaz's Avatar
9.3 Pontiac Olds drop out rear
You have a 9.3 Pontiac / Olds Drop Out third member-
1956 will have the 29 spline axles 1957-1964 will have the larger 31 spline axles.
This rear was AKA ' OLD Gasser rear' VERY BIG, VERY STRONG. They use to use these rears in the Top Fuel cars as it was the strongest rear built in the day. PERIOD.
YES, STRONGER THAN ANY 9" Ford.
Massive 1.875 pinion shaft
12 bolts hold the ring gear in place
Ring gear Diameter 9.3
Rears are expensive to build these days BUT well worth the effort as longevity and strength will prevail.
I sell Posi units for this rear and can get gears. I prefer to sell the hogs heads complete so you know all the parts are installed correctly. JIm
Old Apr 2, 2013 | 12:32 PM
giaguaro's Avatar
thanks for your reply.
As soon as i will be under the car i will ask you more
HitTheHole
Drivetrain/Differentials
Feb 4, 2021 10:46 AM
valmaye
Feb 19, 2012 10:41 AM
cutlasssupreme71
Feb 22, 2011 11:40 AM
aholiday
Jan 11, 2010 05:57 AM
<powers455>
Sep 13, 2007 09:11 PM
