ture or false: 12 bolt rear question
Old Aug 23, 2018 | 12:57 PM
GTMeach's Avatar
I have heard California built 442's in 66 came with 12 bolt rear axles ( 12 bolts as in cover bolts, not necessarily ring bolts)
Old Aug 23, 2018 | 01:12 PM
Oldsmobile started using the Type O axle under the Cutlass line in May of 1966. The Type O has a 12 bolt cover but only ten bolts holding the 8.5" ring gear. It is not a "12 bolt" and no Chevy 12 bolt parts will fit. This was not a function of being built in California - Lansing cars were first.
All Cutlii built in CANADA for 1968-69 DID get the Chevy 12 bolt in place of the Type O, however.
Old Aug 23, 2018 | 03:43 PM
GTMeach's Avatar
Thats interesting..my car is a late May 66 build and has a 12 bolt COVER. Is there any casting, or stamped dates on the rear ends?
Old Aug 23, 2018 | 04:02 PM
Which is consistent with when Olds started using the Type O axle. All assembly plants did this, not just Fremont. You won't find any info in the Chassis Service Manual since that manual was printed in Oct 1965. There is a dealer service bulletin from May 1966 that talks about this.
Old Aug 23, 2018 | 04:28 PM
GTMeach's Avatar
The julian date on the rear is 170. My car was built 05D. Doesnt work...UGH
Old Aug 23, 2018 | 06:23 PM
66-3X2 442's Avatar
Why doesn't it work? That's the last week of May which would be in the 180 range.
Old Aug 23, 2018 | 09:18 PM
GTMeach's Avatar
Thats end of June
Old Aug 24, 2018 | 07:26 AM
66-3X2 442's Avatar
Thats end of June
My bad,sorry.
twilightblue28A
Drivetrain/Differentials
Apr 9, 2016 07:13 AM
johnnyjaws
Mar 15, 2014 08:00 AM
camdon454
Nov 9, 2012 08:53 AM
sworthy555
Aug 5, 2010 04:07 PM
csouth
19
Nov 28, 2009 06:42 AM
