these worth anything?????
I am in the process of removing the 3.73 ring and pinion out of my 7.5 posi rear.
they are Richmond gears. I would love to trade them for a set of 3.23,or 3.42's
they have only 600 miles on them. what should I ask for them?
Guest
Posts: n/a
Not very much, I think, but I'm not an expert on the subject. The other day in the paper there was a GM 12 bolt 1/2 ton Chevy rear diff with 3.73 gears for $75.00, and that was the whole differential, not just the ring & pinion, and truck gears are generally stronger than car gears. That's my understanding anyway, somebody else has got to know a lot more about it than I do. Why do you want the higher gears anyway?
I was concerned that 3.73's and 14" tires would result in engine RPM's being too high at highway speeds
rear gears
With any v8 any gear will be fine. 14" tires are smaller diameter usually so a 2 series gear will be fine . they will definetely not feel like the 3.73 off the line BUT you will really be able to drive the car anywhere with out all the rpm noise level . Gear choice is really what you the customer want your car to do. All around performance is usually high 2's and low 3's on the gears with 2-3 speed tranny over drive and 4-5-6 speed trannies work better with mid to high 3 series gears.
NOW I do not know what all your motor and tranny specs are so this is very general. Jim
trans, is a TCI street fighter TH 400, w/2600 stall convertor. My goal with this project, to make it a fun cruiser, with an occasional stoplight launch now and then
so, I could go ahead and run the 2.73's in the posi?? those 2.73's with the old v6 had a real good launch, might be fun with a very stout big block v8
delta881972
March 4th, 2010 05:14 AM
