Ring and pinion.
Old May 20, 2018 | 07:43 PM
Kyron219's Avatar
Ring and pinion.
Will 8.5 gears fit in 1982 cutlass supreme brougham
Old May 20, 2018 | 08:13 PM
svnt442's Avatar
Not in the stock axle, as it's a 7.5/7.675 housing.
Old May 20, 2018 | 08:23 PM
Kyron219's Avatar
I'm thinking of switching the ring and opinions out to 8.6/8.5 gears..30 spline carrier and I don't know if I would have to change the axle shafts tho...
Old May 20, 2018 | 08:26 PM
Kyron219's Avatar
Another thing would I have to change those side gears in the axle housing if so what are those gears called ????
Old May 20, 2018 | 10:29 PM
monzaz's Avatar
8.5 and 7.5 rears both 10 bolts but not the same
Are you understanding that you need a 8.5 HOUSING axle assembly and if you have a stock 1978-1983 g-body car NON had 8.5 rears. ALL were 7.5
1984-1987 Grand National and t-type turbo cars had the 8.5 and the 442 also got the 8.5 optional bigger rear end axle housing assembly.
Regular cutlass only had the 7.5 from 78 - 87
Top picture is 8.5 and the bottom is 7.5 rear. you can not switch inner parts from one to the other.
hope that is clear for everyone to understand.
Jim
J D
Old May 20, 2018 | 10:33 PM
Kyron219's Avatar
Jim
J D
ok thanks I'm still new to this and that's the answer I need so now ill start looking for that housing
Old May 20, 2018 | 10:35 PM
monzaz's Avatar
axle shaft upgrades
10 bolt 7.5 G-body rears were 26 spline axles and can be upgraded to 28 spline axles with swapping out a 1990-2002 7.625 posi or open carrier. and then buy the correct 28 spline axle shafts
10 bolt 8.5 Gn and 442 rears were 28 spline stock and can be upgraded to 30 spline with again 1990 -1996 gm limited slip posi or open one wheel peel carrier that were 30 spline or aftermarket 30 spline carrier of coarse.
Then buy again the correct aftermarket 30 spline axle shafts.
I can get anyone the parts to do these conversions for each of the rears.
Jim
J D
Old May 20, 2018 | 10:36 PM
monzaz's Avatar
how much is too much?
You really should determine how much diff you need to do the job you want the car to do.
If you are mostly street bound and are above the 12 sec mark at the track the 7.5 upgraded rear will do the job just fine.
DZAUTO
Mar 27, 2018 04:19 PM
Powerm01
Jan 1, 2018 02:09 AM
oldspackrat
Aug 10, 2014 10:03 PM
trdbrd
Mar 23, 2009 05:34 PM
brian j combs
Aug 10, 2007 09:34 PM
