Ring gear question
Old Jun 5, 2022 | 03:52 PM
67Rocket's Avatar
Ring gear question
After removing the rear brake drums with a lot of effort, the axles rotate with out the ring gear and pinion turning. Every thing worked as it should prior to pulling the drums. The axles have c clips and the clips and spider gears have not changed. Thanks for any and all help.
Old Jun 5, 2022 | 04:40 PM
BillK's Avatar
Do you actually have the cover off so you can see the ring gear ?
Old Jun 5, 2022 | 04:48 PM
67Rocket's Avatar
Yes, the cover was removed
Old Jun 5, 2022 | 05:12 PM
BillK's Avatar
Well something does not make sense. Unless you have a non posi rear and then when you are turning one axle the other one is moving the opposite direction. Is the driveshaft still hooked up ? The ring and pinion cant move if it is.
Old Jun 5, 2022 | 06:45 PM
^^^This. Or an anti-spin rear in desperate need of new clutch plates.
Old Jun 6, 2022 | 08:13 AM
monzaz's Avatar
PICTURES are worth a thousand words and solve headaches real fast. Jim
Billyaxe
Drivetrain/Differentials
Apr 30, 2021 02:35 PM
71OldscutlassS
Jan 25, 2020 07:43 AM
67Rocket
Jun 5, 2017 07:15 AM
Gary M
Oct 22, 2016 08:59 AM
67Rocket
18
Apr 25, 2016 10:28 PM
