Rear gear oil
Old Aug 4, 2022 | 11:37 AM
old greybeard's Avatar
69 Cutlass S
Rear gear oil
69 Cutlass, factory Chevy 12 bolt rear. Not a limited slip. Chassis manual calls for sae 90, hard to find.
Can I safely add a multi viscosity gear oil?
Old Aug 4, 2022 | 11:41 AM
Sugar Bear's Avatar
Yes.
I know this is for the rear diff but try to avoid GL 5 if it is a 4 speed car because you can't multipurpose the fluid. GL 5 likes yellow metals in manual transmissions i.e., it eats them!
Old Aug 4, 2022 | 01:25 PM
You can use 80/90 or 75/140 if you're not driving in extreme cold winters.
Old Aug 4, 2022 | 01:39 PM
69 Cutlass S
I do have some 80-90 conventional on my shelf and will top off with it. The straight 90 is hard to find and expensive.
thanks
Old Aug 5, 2022 | 08:57 AM
monzaz's Avatar
I do not know many places that sell straight weight oil anymore.
Any rear diff fluid will be fine and provide good protection
Open diffs are really tolerable to anything.
I always tell everyone...LOW or NO fluid is what will really mess a rear end up. Lubrication is KEY ...keep the level up of WHATEVER you install. Jim
Cincinnati Rick
Jul 22, 2019 05:16 PM
72cutlassdog
Drivetrain/Differentials
Jul 2, 2018 05:00 AM
sammicurr86
May 20, 2018 08:52 AM
foo
Aug 14, 2014 06:48 PM
monaco
Dec 21, 2013 07:13 AM
