Rear end question 68 Cutlass Rebuild
Old Oct 20, 2013 | 11:04 AM
Xlhowie's Avatar
My rear end has this number on the fwd pass side axle CB 012?B. other side is GM53 and casting number 3917123NF and A14 9.
Can anyone tell me what this is and the ratio? Thanks much
Howie
Old Oct 21, 2013 | 04:40 AM
monzaz's Avatar
10 bolt 3.36 rear
Howie
3.36 NON POSI rear chevy 10 bolt
Old Oct 21, 2013 | 07:42 PM
507OLDS's Avatar
Cast January 14th,1969. Although the finish date should be after the casting date,so not sure if all those numbers are right.
Old Oct 22, 2013 | 05:38 AM
Xlhowie's Avatar
Yeah my question also, but just verified numbers
via photos I took of the rear end. Numbers are correct except the is an X over the casting number and an O over the date. I got the car partially started and am finding things don't match up,
thx, Howie
Old Oct 22, 2013 | 05:40 AM
Xlhowie's Avatar
3.36 chevy 10 bolt is my best assumption also. Trouble now is figuring what speedo gear to use, I'm guessing a 42 or 43. ANY HELP???
26" tires, 18 tooth output shaft speedo gear?
Thx, Howie
Old Oct 22, 2013 | 05:43 AM
monzaz's Avatar
thread
Start a NEW thread with trans speedo gear which one. You will get a better turn out of answers that is a trans question. Jim
Old Oct 24, 2013 | 10:47 AM
Xlhowie's Avatar
I ended up having to call a tranny specialist. He said with 26" tires I'd need a 46 tooth gear which is not possible. He said I'd be 1.5 mph high at 50 so I will use bigger tires and that will fix that. Thx, Howie
monzaz
Oct 28, 2023 10:58 AM
350TurBRO
Sep 12, 2014 11:52 AM
theoldsrocket
Apr 10, 2013 05:52 AM
monzaz
Mar 4, 2010 06:49 AM
crank.it
Drivetrain/Differentials
Apr 30, 2003 07:01 AM
