Rear end question 68 Cutlass Rebuild
My rear end has this number on the fwd pass side axle CB 012?B. other side is GM53 and casting number 3917123NF and A14 9.
Can anyone tell me what this is and the ratio? Thanks much
Howie
Howie
Yeah my question also, but just verified numbers
via photos I took of the rear end. Numbers are correct except the is an X over the casting number and an O over the date. I got the car partially started and am finding things don't match up,
thx, Howie
thx, Howie
3.36 chevy 10 bolt is my best assumption also. Trouble now is figuring what speedo gear to use, I'm guessing a 42 or 43. ANY HELP???
26" tires, 18 tooth output shaft speedo gear?
Thx, Howie
Thx, Howie
I ended up having to call a tranny specialist. He said with 26" tires I'd need a 46 tooth gear which is not possible. He said I'd be 1.5 mph high at 50 so I will use bigger tires and that will fix that. Thx, Howie
monzaz
Oct 28, 2023 10:58 AM
monzaz
Mar 4, 2010 06:49 AM
