REAR END QUESTION
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
what is the difference between a chevelle rear end and cutlass? i found a posi rear from a chevelle, and i know it will bolt right on, but what is the difference? the olds rear ends are way more expensive and i was wondering why if the chevelle rear will fit with any problems. thanx for any help in advance. Jay
what is the difference between a chevelle rear end and cutlass? i found a posi rear from a chevelle, and i know it will bolt right on, but what is the difference? the olds rear ends are way more expensive and i was wondering why if the chevelle rear will fit with any problems. thanx for any help in advance. Jay![Smile](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
A chevy 68-72 10 or 12 bolt will bolt right in. You will need to get a special u joint or use the Chevelle drive shaft because they use a different u joint.
350TurBRO
September 12th, 2014 11:52 AM
