Rear end numbers help needed
Old Aug 5, 2018 | 09:44 AM
yellowone's Avatar
These are the rear end numbers on my 1972 Cutlass Supreme. Need help to see if they are "matching" to my VIN. The last numbers of my VIN are 129999.
Old Aug 5, 2018 | 10:46 AM
I have never seen a rearend with a VIN stamp on it. They have a code for the gear ratio and posi/open carrier, the manufacturing plant, and a date code.
Your picture decodes as:
SA = 2.73:1 ratio, open carrier (non-posi)
B = Buick plant
288 = day of the year manufactured
2 = I don't know what this means.
Old Aug 5, 2018 | 11:26 AM
yellowone's Avatar
Rear end
Thank you for the help. Buick, wow. Wonder if this has been a replacement? My transmission and engine block match the VIN, was hoping the rear end was too. Thank you so very much for Decoding it for me. Hopfully I will have time to upload pics of the car and fill out my bio soon.
Old Aug 5, 2018 | 11:29 AM
No, not a replacement rearend. There were multiple GM divisions making the corporate 10 bolt rears and Buick manufactured rears were frequently put in the Olds Cutlass from the factory.
Old Aug 6, 2018 | 12:03 PM
The rear axle is not part of what most people call 'numbers matching' for the simple reason it's an easily swapped out part, much like cylinder heads. The SA axle was common for 72 Cutlass S and some Cutlass Supreme's. What factory and model is your car?
Old Aug 6, 2018 | 02:14 PM
yellowone's Avatar
Factory was Arlington, Texas. Cutlass Supreme 3J57H2R First7 digits of VIN.
Old Aug 6, 2018 | 03:52 PM
Which is exactly what I posted on your other thread. The rest of the VIN (which is not really secret) is the production sequence at Arlington. All assembly plants for A body started at sequence 100001. Judging by your build date and knowing that Arlington wasn't really a high production factory, I'd guess it to be somewhere in the range of 1020000 to 104000? Maybe less.
Just an FYI, my car was built at Lansing and the axle code was O and ordinal date was 101 which was exactly the date my car was on the final assembly line. I have the documentation from GM showing when it rolled off the production line on April 10, 1972 and how it was equipped, where it was sent, and how many were sent there.
Old Aug 6, 2018 | 05:28 PM
anthonyP's Avatar
From what I understand and have seen, the 71/72 Oldsmobile A-bodies built in Lansing and Framingham received Oldsmobile axle housings, and those built in Arlington and Fremont received Buick axle housings
Old Aug 6, 2018 | 09:08 PM
11971four4two's Avatar
MOTORHEAD
10 bolt 8.5
is there a large letter A cast into the front
towards the engine center section??
Old Aug 12, 2018 | 10:42 AM
monzaz's Avatar
numbers
B = Buick plant <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< pretty sure this is BUFFALO PLANT
2 = I don't know what this means.<<<<<<<<<<<<<< This should be shif. 1st 2nd or 3rd shift.
Old Aug 12, 2018 | 10:56 AM
10 bolt 8.5
not on mine. 72 10 bolt 8.5
Old Aug 12, 2018 | 11:08 AM
Oh, I just assumed the B was for Buick.
So as to not make any further assumptions, how do the numbers on my 1971 rear decode?
Old Aug 12, 2018 | 12:00 PM
Kenneth, is your car an Arlington car? If yes I'd guess Arlington, 2nd shift ordinal date March 9, 1971
Old Aug 12, 2018 | 01:29 PM
Nope, Lansing.
R2 = 2.56:1 ratio,open differential
I was referring to the other numbers. I had assumed the B in the OP's picture meant Buick and was wrong, so I didn't want to assume the first letter/digit in my number was an O to designate Oldsmobile.
dewcrazzy
Aug 28, 2015 12:31 PM
doby
Mar 14, 2013 04:01 AM
metalmen
Aug 16, 2012 02:05 PM
blackhawk
Dec 26, 2011 08:12 PM
lovinbeinamom
Aug 9, 2006 02:09 PM
