Rear end/gears
Old Apr 19, 2014 | 06:40 AM
Her69olds's Avatar
Smile Rear end/gears
So is it true that I have a 12 bolt rear end with 10 bolt gears in it?? If so how do I find out which gears I have without taking it to a shop, and if I wanted to order some gears for it such as 3:73 gears which ones do I order. All I know right now is that my rear end is non posi (one wheel wonder). I have a TH350 that I am getting rebuilt real soon. I was told that getting a shift kit, stall and gears would make a world of difference. What is a good setup for a stock 350 rocket #395558 2, quadrajet 4bbl, edelbrock performer intake? Just looking to have a little more fun from red light to red light!!!
Old Apr 19, 2014 | 09:04 AM
oldstata's Avatar
Justin
The posi for the olds 12 bolt is made from a ford 8.8 set up you can get them I would look up monzaz (Jim ) or 507olds ? Brain trick
Gears are not currently made for these from my understanding but you can get used/ old stock
Best way to get gearing is to pull cover and there are some numbers to read there are others ways I will let some one else explain the methods
Old Apr 19, 2014 | 08:45 PM
507OLDS's Avatar
There are zero aftermarket gears available for the 12-bolt O-axle right now,and the original GM gears are scarce. There was never a 3:73 ratio for this rear.Your choices,in that range,are 3:42 and 3:90,if you can find them.
A few alternatives are the 71-72 8.5" 10-bolt,or the 12-bolt Chevy. Both of these have plenty if parts available.
Old Apr 19, 2014 | 08:48 PM
I know he's a smart guy, but......
Old Apr 19, 2014 | 08:50 PM
oldstata's Avatar
Justin
Lol Brian
350TurBRO
Sep 12, 2014 11:52 AM
boc23
Drivetrain/Differentials
Aug 29, 2014 02:23 PM
monzaz
Aug 7, 2014 11:12 AM
monzaz
May 29, 2010 08:46 PM
idaholc
Apr 13, 2009 01:33 PM
