rear end?
Old Jun 22, 2007 | 03:16 PM
shvelhed88a's Avatar
rear end?
got a 12bolt o type rear end order chevy 10 bolt gears for it but cant get the the ring gear to bolt up looks like everything should bolt up but wont
Old Jun 23, 2007 | 06:41 AM
It won't bolt up because they are completely different rear axles. You might as well try installing Ford gears. Sell the Chevy gears and get the correct gears for a Type O axle.
Old Sep 4, 2007 | 08:47 AM
monzaz's Avatar
rear
YEP... That carrier in the 'O' type may look like a 8.5 but it is NOT. The bolt pattern is slightly smaller bolt circle and the inner ring gear diameter is also larger. The pinion is another difference. The 12 bolt 'O' type is 27 spline and is shorter than the 8.5 30 spline pinion. JUST WILL NOT HAPPEN....with out some serious machining...lol.
What ratio were you going for?
350TurBRO
Sep 12, 2014 11:52 AM
MDchanic
31
Aug 12, 2012 04:24 AM
martine
Drivetrain/Differentials
16
Sep 13, 2007 10:12 PM
<George>
Jul 12, 2004 11:00 AM
crank.it
Apr 30, 2003 07:01 AM
