Rear diff chatter
Old May 13, 2025 | 07:48 AM
72455's Avatar
1972 U code Supreme
Rear diff chatter
So lately I'm hearing rear diff chatter from my '72 Supreme. It only seems to happen after driving for an extended period of time (like maybe for an hour or more), so I'm guessing it's only when it's reached a certain temperature. I've checked the fluid level and it's good, and it's not getting excessively hot (about 130 deg). I've put 20K on it since I bought it 7 years ago, and I'm not sure when the fluid was last changed, so I'm thinking that would be a good start.
For reference, it's a 3.08 limited slip unit.
Old May 13, 2025 | 08:11 AM
70sgeek's Avatar
'72 Cutlass ragtop
Yep change the fluid first and look for shavings in the drainage.
Reach inside the housing and fully scoop out all the old fluid you can by hand so you are starting as fresh as possible.
Old May 13, 2025 | 09:38 AM
OLDSter Ralph's Avatar
Don't forget to add "Friction modifier" (Limited slip additive) if its not in the rear differential oil.
Old May 13, 2025 | 10:33 AM
monzaz's Avatar
Yep, We always had to switch out oil about 3 years with the Bigger 31 -33 inch tall tires in the 1/2 trucks. It is a steel clutch thing usually... you might have to shuffle the clutches too that helps. They get glazed and ride on the same clutch and make a nice mirror finish with the other clutch and then go window PAIN of you... So think about that too.
Old May 13, 2025 | 11:05 AM
72455's Avatar
1972 U code Supreme
"Shuffle the clutches??"
Old May 13, 2025 | 01:47 PM
You are probably hearing the limited slip clutches chatter. This was a common complaint when I worked at the Buick/Cadillac dealership. People didn’t like the pop/chatter in their big Roadmaters/Fleetwoods!!
Before doing anything, find a big empty parking lot and make about 10 figure 8 maneuvers.
If that doesn’t help, change the fluid. Clean out as much of the old crap as possible, inspect for excessive debris. Refill with the proper fluid(make sure it’s compatible with limited slip) and take it for a test drive with the figure 8s again. Hopefully that solves the issue. If not, add a bottle of limited slip additive.
Old May 13, 2025 | 06:26 PM
72455's Avatar
1972 U code Supreme
If I do end up changing the fluid, will I need sealer for the new gasket, and I'm guessing I should tighten the diff cover bolts in sequence?
Old May 13, 2025 | 06:43 PM
Hi Dave - Hand tighten all bolts first so they are all snug into the receiving thread holes. Tightening a rear differential cover should be performed in a crisscross/diagonal pattern, IOW begin with one bolt then proceed to the next bolt directly across from that bolt on the opposite side of the differential cover.
Yes. Add a very minimal amount of gasket sealer to surround the entire differential ensuring you encircle each bolt hole. Don't go gorilla nuts on the amount of sealer. I think the torque value for the bolts is 30 ft-lb but look in the CSM.
Old May 13, 2025 | 07:08 PM
Pattern I follow...
Old May 13, 2025 | 07:25 PM
Originally Posted by 72455
If I do end up changing the fluid...
You've put on 20K miles since taking ownership, your car was at one time a race car, you haven't changed the oil & if you have no receipts validating the last time differential fluid was changed, please change your fluid at your earliest convenience. Your rear end will thank you.
Old May 13, 2025 | 07:55 PM
You need to clean both surfaces - cover & differential - be careful - no gouges. Stuff some t-shirts or similar inside the differential in case you have old gasket material flying everywhere while scraping off old gasket. T-shirts are nice because they don't shed lent material & they soak up the old cruddy oil nicely. Once you get to about the final stage of cleaning the mating surfaces, you can use some brake cleaner to wash them. I have bags of steel wool. I use steel wool embedded w/ some brake cleaner to give the mating surfaces a final cleaning rub-down. Clean the bolts well w/ a wire brush. Here's something else I do which is overkill most likely. I put the bolts I removed back into the same holes I removed them from.
Image of the front differential on my F250 4x4 to give you an idea of amount of gasket sealer. Something to note regarding gasket sealer(s). I never tighten bolts to torque value right away. I put on sealer, let sealer set thirty minutes, install cover w/ gasket, hand tighten all bolts, torque to 1/2 torque value, let valve cover set at 1/2 torque values for one to two hours, then apply the final torque. You get a better seal when the gasket sealer has a little bit of time to cure before final torque. Easy peasy. I'm getting ready to change my transfer case fluid in a week or so. This was the 4th time I changed front differential fluid (image). Truck has 200K miles.
Old May 13, 2025 | 08:22 PM
72455's Avatar
1972 U code Supreme
Norm, are you referring to the engine oil?
Old May 13, 2025 | 08:24 PM
72455's Avatar
1972 U code Supreme
Old May 13, 2025 | 08:25 PM
Say what? Didn't you state you haven't changed the diff fluid since you've owned it? Huh?
You realize diff fluid is an oil, right?
Old May 13, 2025 | 09:05 PM
72455's Avatar
1972 U code Supreme
Ok...I was just making sure we were on the same page
Old May 14, 2025 | 05:42 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have only seen diff chatter once. It was new in the late 90's Ford 3/4 ton we did a synthetic gear oil change at the Ford dealership I was apprenticing at. At the time $22 per quart for Ford synthetic 75W90, ah stealerships. Turns out Ford didn't spec it with posi additive, crazy for that price. It was ugly enough paying $25 a quart, needed two for glorified trans hydraulic fluid, could tell by the clear colour and smell for my Challenger's transfer case two years ago. We added the additive tube and no more chatter in that Ford. We just did a 3.08 posi in my 70 Cutlass S Type O 12 bolt with the brand new $$$ Yukon posi and used 3.08 gears. Boy it sure does grip, squirrely flooring it around corners and no wheel spin. I used 85W140 conventional, supposedly has the additive. Synthetic isn't suggested with most posi but I do run synthetic 75W140 in my Dakota's 8.25" 3.91 posi, sees -40 temps. I stil added a tube of CRC posi additive in the Olds, completely quiet. I like to RTV a gasket to the cover, W27 in this case. Then if it needs pulled, no scraping and redoing. I did have to retighen it after the initial drive and has been good since. I found a surprising amount of metal in the 2.78 open I replaced and I had just done the gear oil a couple of years earlier. Good luck.
Old May 14, 2025 | 03:34 PM
72455's Avatar
1972 U code Supreme
Does that reset the clutches?
Old May 15, 2025 | 08:22 PM
The figure 8 removes the glazing of the clutch plates, and works oil into the friction I vaguely remember a service bulletin suggesting the figure 8 as the first step.
Old May 17, 2025 | 03:52 PM
72455's Avatar
1972 U code Supreme
This should be done at normal parking lot speed, correct?
Old May 17, 2025 | 04:24 PM
Pedal to the floor billowing black smoke burning up the parking lot in figure eights...that's what I'm talking about.
Old May 17, 2025 | 04:50 PM
Dave - For a couple bucks ($8.95) why not turn those eights into some serious fun.
Old May 17, 2025 | 05:00 PM
72455's Avatar
1972 U code Supreme
Ha ha...Norm's got jokes!
Old May 17, 2025 | 05:06 PM
Gotta enjoy this stuff...
Old May 17, 2025 | 05:55 PM
72455's Avatar
1972 U code Supreme
No kidding...with the turn radius on these relics, I'm gonna need 3 miles of open space just to do my figure 8s...
Old May 18, 2025 | 11:35 AM
gs72's Avatar
72Cutlass S
That is exactly what I pictured when I first read that.
Old May 19, 2025 | 01:33 PM
Replace the steering wheel with this!!
And you need to wear this while driving!!
JRamage
Jun 13, 2023 04:38 AM
72455
Mar 8, 2022 10:58 AM
72455
Jul 17, 2021 11:34 AM
jpc647
Jun 24, 2014 10:11 AM
terrapin
Aug 17, 2012 04:25 AM
