rear axle info
Old July 30th, 2020 | 10:34 AM
McIntosh's Avatar
rear axle info
Guys
I have a 70 Cutlass S with the dreaded 12 bolt cover, ten bolt ring gear rear with 2.56:1 gears. I built a 455 this spring and this just won't do anymore. I see a used Olds 12 bolt posi for sale they say is from a 67 442. It's a posi with 3.08:1 gears. I think the ratio is perfect for me. My question is will it fit? I had been looking for one from a 68-72 A- body. Is a 67 so different? I was hopping to find one of the Corporate 8.5 inch ten bolts. I've seen a few of them but from later years then 72. Anyone know what fits? Do I need to stick with the 68-72 A-body rearend?
Old July 30th, 2020 | 01:52 PM
69CSHC's Avatar
A 12 bolt Olds rear in 67 is a type O, and the same as your 1970 type O. It will fit, if its in good working order and the price is right go for it.
As far as being dreaded, just keep in mind its an 8.5 rear same as the corporate.
Old July 30th, 2020 | 02:05 PM
The "dreaded" part is the 2.56:1 gear ratio. Both my 70 and the 71 were cursed with that from the factory, but luckily I was able to rectify both of those.
Cory Kloter
Drivetrain/Differentials
September 4th, 2019 07:10 PM
Bozang1
July 10th, 2015 02:33 PM
Chevyguy
October 7th, 2013 04:55 PM
My72Cutlass
June 14th, 2013 09:34 AM
DarrylJ
December 11th, 2008 07:49 PM
Quick Reply: rear axle info
