Differential Oil Capacity
Old Jul 29, 2020 | 11:34 AM
anoldsman's Avatar
I am rebuiling the posi unit out of my 1970 Olds Cutlass. The carrier is a "672" casting but I am unsure if the rest of the differential is the '67-69 or the correct for the car '70. I have a stock type cover and an aftermarket W-27 aluminum cover. How much gear oil will be required for each cover (if different). Will the aluminum help with cooling?
Old Jul 29, 2020 | 11:53 AM
Add oil until it is just at the bottom of the fill port.
Old Jul 29, 2020 | 12:37 PM
anoldsman's Avatar
Old Jul 29, 2020 | 01:02 PM
I fill it until its about a 1/2 inch below the fill port or basically when I can reach my index finger in and bend the the first digit and touch it.
Old Jul 29, 2020 | 01:09 PM
OLDSter Ralph's Avatar
Be sure you add the "anti spin additive" (posi additive) when filling.
Old Jul 29, 2020 | 03:12 PM
monzaz's Avatar
Buy 3 quarts that will be plenty.
Do fill on a flat surface until the oil back washes from the fill plug area.
After driving the car a few days double check and top off as needed as the posi will hold some fluid in the clutches and the axle tubes will also hold some after the first drive run happens after any full clean out rebuild.
Jim
JD Race
Old Jul 31, 2020 | 11:10 AM
anoldsman's Avatar
Jim
JD Race
sammicurr86
Drivetrain/Differentials
May 20, 2018 08:52 AM
cdrod
Mar 30, 2014 02:53 PM
ollerich29
Jul 22, 2013 09:09 AM
Delmont 88 PA
Jun 28, 2012 01:38 PM
sammieolds
Jul 15, 2010 01:27 PM
