Rear Axle Flange to Backing Plate Gasket???
Old Sep 16, 2010 | 09:38 PM
oldzy's Avatar
Looking through my resto parts catalog, it mentions a 'Rear Axle Flange to Backing Plate Gasket'.
I don't recall seeing any of these gaskets when I pulled rear end apart. I thought the rear backing plate just mounted to the axle tube, 4 t-bolts/nuts... done. Am I missing something?
Old Sep 17, 2010 | 04:35 AM
507OLDS's Avatar
They are usually disintegrated by now,but they did put a very small/thin gasket between the backing plate & the tube flange.Not a real neccessity,but you can smear a little RTV in that area.
Old Sep 17, 2010 | 07:20 AM
Gear lube will seep out onto the brakes if you don't use some sort of gasket, but like Brian, my "gaskets" come in a tube.
Old Sep 22, 2010 | 06:22 AM
monzaz's Avatar
GAsket flange
Those gaskets were never designed to hold fluid from seeping as you have a seal in the axle tube and or if you are using A9 the seal on the axle. Pontiac used a STEEL shim with NO sealent at all - gasket was to keep parts from rusting together most likely.
As Brian stated mostly not necessary in most cases.
Remember the oil WILL seep through the retainer around the axle pressed in surface even if you use a sealant...Please look at how it is all put together ... sealing this retaining plate will not stop leaks. Only your axle seal will.
Good luck. Jim
Old Sep 22, 2010 | 07:30 AM
Jim is of course correct. I'll just add that I use RTV on the backing plate to flange joint to keep dirt out of the axle bearing. Admittedly there shouldn't be much, but driving through a rain puddle will splash dirty water up at the backing plate.
Old Sep 25, 2010 | 05:55 PM
OLDSmobility's Avatar
I just installed a custom 9" Ford rearend with Moser axles that use sealed bearings. I was instructed by the manufacturer not to use an axle seal, but to smear a little RTV on the outer bearing race and in the axle tube where it seats.
However, the '67 8.2 P-type rearend that it replaced had two on each side...one between the brake backing plate and axle tube flange and another between the axle retainer and the backing plate.
Old Sep 27, 2010 | 05:49 AM
507OLDS's Avatar
Regardless of what that gasket was intended for,it won't stop oil from getting on your brakes.If you have an oil leak,you have a bad seal,and it would need replaced.
HitTheHole
Drivetrain/Differentials
Feb 4, 2021 10:46 AM
caddy
Mar 15, 2013 11:00 AM
Chesrown 67 OAI
Oct 27, 2010 05:56 PM
luvmy58
May 12, 2008 08:00 PM
stuart
Brakes/Hydraulic Systems
Dec 16, 2004 09:23 PM
