Question on Axles/hubs
Old Sep 14, 2009 | 10:19 AM
CJR's Avatar
CJR
I'm in the planning process to build a mid-engine car using a Toronado transaxle. What axles/hubs/knuckles(i.e. uprights), with disc brakes, can be used with my 67 Toronado transaxle? I want to use Toronado axles that allow "plunge" (axle length change) to improve handling. Can anyone recommend various combinations?
Best regards,
CJR
Old Sep 14, 2009 | 12:13 PM
Best regards,
CJR
Back when Bill Porterfield was running Mid-Engineering, he used Corvette hubs and swing arms with custom axles to mate to the TH425.
Old Sep 15, 2009 | 09:26 AM
CJR's Avatar
CJR
Were all the Toronado drive shafts of the "plunge" type( length changing)? If not, what years were? Photos of some Toronado axles, that I saw, show a flange to bolt-up to the transaxle, a CV joint, shaft, universal joint, and a splined end to go into the hub. I didn't see a telescoping section( like a driveshaft that moves in and out of a standard trans). Was the splined end free-floating in the hub without the typical attachment nut? Any pictures would be appreciated.
Best regards,
CJR
Old Sep 15, 2009 | 04:13 PM
Best regards,
CJR
Most FWD axle shafts have the axial length change feature inside the CV joint.
Old Sep 16, 2009 | 12:19 PM
CJR's Avatar
CJR
Joe,
Thanks for the info on how the Toronado half shafts plunge. After your comment, I found a description in one of my manuals. Apparently, the plunge is in the CV at the transaxle.
What wheel hub/knuckle assemblies can you recommend for the Tornado half shafts that would use disc brakes?
Best regards,
CJR
Billybear
Jul 12, 2013 06:40 PM
costpenn
Feb 22, 2013 07:29 AM
68 D88
Jan 4, 2013 11:57 AM
Aceshigh
Brakes/Hydraulic Systems
Sep 28, 2011 09:43 PM
txuslb25
May 26, 2010 11:18 PM
