help i need hubs
Old Jul 11, 2013 | 06:57 PM
Billybear's Avatar
help i need hubs
i need new hubs for my 65 jetstar and can not find them can you guys help me with this im looking for the fronts
Old Jul 11, 2013 | 07:07 PM
A J88 should use the same hubs as an A-body (Cutlass/442). I'm curious about the recent spate of people needing hubs, however. What's wrong, exactly? The only thing I can imagine are either broken wheel studs or torn up races for the bearings. Both can be replaced.
Old Jul 12, 2013 | 06:27 PM
tru-blue 442's Avatar
Old School Olds
Joe, I think the holes are starting to waller
out from all the Chiniesum bolts that don't
fit right. Yes, they fit ok for now, but the shanks
where they fit in the hub are short on the 'grabbers',
for lack of the proper name. Over time they kill the hubs.
They just don't fit worth a damn and can loosen up, and if your not
careful, you have a wheel that wont come off because the
bolt is spinning in the hub.
I remember years ago, you had to heat and beat to get the
factory ones out... they fit that well. They never spun out,
they freaking broke or stripped the threads.
Old Jul 12, 2013 | 06:40 PM
OK, thanks. I've had this happen before - with a factory stud, actually. I just tack welded the stud to the backside of the hub. Problem solved. By the way, the technical term for "grabbers" is "knurl". You can get lugs with oversize knurls for this problem.
smokinjoe33
Jan 25, 2015 08:29 AM
68 D88
Jan 4, 2013 11:57 AM
Aceshigh
Brakes/Hydraulic Systems
Sep 28, 2011 09:43 PM
txuslb25
May 26, 2010 11:18 PM
CJR
Drivetrain/Differentials
Sep 16, 2009 12:19 PM
