Posi Rear End
Old Jan 16, 2025 | 11:14 AM
drshrpe's Avatar
Question Posi Rear End
Good afternoon, I had to come to the experts before I made this purchase. I wanted to know if this is truly a positive traction chunk and will it fit my 1975 Oldsmobile Delta 88? Also, are there any other options to add positive traction to this rear end? I believe it is a 12 bolt 9.3
Last edited by drshrpe; Jan 16, 2025 at 11:35 AM. Reason: Add additional information.
Old Jan 17, 2025 | 05:03 AM
monzaz's Avatar
That is not a 9.3 it is a 8.875 Pontiac posi unit from 1965 - 1970 era
I REPEAT----- NOT A 9.3 OLDS center!!!!
The cover this posi unit fits has a 10 bolt cover and 12 bolt ring that measures 8.875 and has 31 spline axles AND will only fit the 1965 - 1970 era because it has 30 degree cut axle spline side gears.
Jim
JD race
Old Jan 17, 2025 | 05:04 AM
monzaz's Avatar
NO OTHER options than you to find a good used unit. Sorry.... Same with gearing. NO AFTERMARKET POSI OR GEARS.... Just bearings for rebuild of what you have.
Old Jan 20, 2025 | 08:43 AM
drshrpe's Avatar
Thank you for the help. Definitely saved me.
Old Jan 21, 2025 | 04:27 PM
monzaz's Avatar
The ring gear is NO GOOD with out the pinion too. So do not let them think your getting a ring gear worth something - unless the pinion matching goes with it.
Old Feb 15, 2025 | 11:56 AM
69Oldsman's Avatar
I have a buddy that has a 76 Olds Custom Cruiser. He used a Corvette posi unit in the big Olds rear axle. He had to use the 3.08 gears with it.
wills30
Nov 9, 2024 08:57 AM
eric66
Jan 28, 2022 06:08 PM
Blackjack419
Nov 13, 2021 08:16 AM
J1978
Wheels and Tires
Apr 6, 2021 09:10 PM
dredluxx
Oct 22, 2016 11:25 PM
