Pick n Pull rear end???
So, I have a 72 cutlass with the 8.5" 10 bolt (scalloped cover) open rear end. I'm looking to make this a 3.42 rear end with posi on the cheap. Is there a way to pull parts from a more modern junk yard car that would be able to swap in? If not, is there a rear end that will work with few modifications?
Have a look at Richmond GEar's web site for the 8.5" 10 bolt applications. There are a lot of newer vehicles you can pull the posi from:
http://richmondgear.com/pdf/Richmond...n1.pdf#page=31
Cheap
Here is the problem with cheap. ALL the posi units yu are seeking are well over 30 years old and these units are likely used up and will need rebuilding which the 10 bolt 8.5 S spring units are not very good as parts are NOT available anymore... I have a few clutch packs left and they sell for 225.00 a set. Spider gears are totally gone in the dealers etc. 5-7 years ago I found 2 spider gear sets for the 8.5 units and the dealer want 359.00 for a set.
SAVE your money and BUY NEW parts. Gears are readily available in all the pick-up trucks 1/2 ton 3.42 3.73 are plentiful for sure. They will work good to keep that part of the money down. Posi unit BUY new...
My opinion but you can keep trying ...Maybe someone on this sight will sell a good used one.... But remember you will not know how much life is left till yo get it in and drive it. Jim
J D
Pretty sure I have a good set of used 3.42 gears right now.
J D
Not knocking new but if someone can can grab his own parts and assemble his own stuff and have something going that still works for under $200 total its alot cheaper and maybe not everyone can afford all new everytime and go for a $1000 build. Heard this argument a hundred times but yet I will still install a 40 plus year old posi unit and it will perform well over and over again. Yes some stuff is wore out but you inspect it and test it if possible. If its tight and still grabs well it can work fine. If its just a street car on street tires occasionally doing a burnout it is not much strain on the P unit. If your going to drag race frequently at the track on slicks doing many slick burnouts it can be too much for an old unit after a while but then a spool or a new HD unit wouldnt have been the smarter choice then. But for Joe blow enjoys his car and lights em up here and there its fine.
350TurBRO
September 12th, 2014 11:52 AM
