Oldsmobile 12 Bolt Type "0"
Hello,
Wondering if anyone is looking for or interested in a 1970 12 bolt type"O" axle? I recently aquired one by mistake (was led to believe it was a gm 12 bolt only to get it home and apart to realize it has a 12 bolt cover with a 10 bolt 8.5" ring gear) It is for A body cars so assuming it should fit anything from 68-72 right? I went through it any way and it is actually in really good shape, has 28 spline bolt in axles, open spool with 2.78 gears. I can email pics if anyone interested...I am a chevelle guy so would rather see this go to someone who will put it where it belongs under a cutlass 442 or something of the like, rather than me stick it under a corporate car. From the reserach i've done these came in most '69-'70 cutlass's.
I paid $500 for it but will let it go for $350 to a good home...anyone?
Thanks,
Zack
Thanks,
Zack
Ya i figured i wasn't the first guy this happend to...alot of people i've talked to didn't even know there was such a thing as a type O 12 bolt it even took me some time to figure out exactly what i had. I tried returning it but the "nice at the time" individual i bought it from's demeanor abruptly changed and he wouldn't allow it...originally when i looked at it he had told me it came out of a '70 chevelle (leading me to believe it was the true 12 bolt) he even had the car there that it came out of, but what he conveniently failed to mention was that it wasn't in that car originally. Basically he tricked me, he didn't lie but he with held just enough info to get the cash...when i called him back after i got it home and realized what it was he told me "it was my problem now" and "i can take him to court if i want". Im not a sue happy a-hole though and not about to waste a bunch more $ in court and lawer fee's over $500 rear end. It's a shame people gotta be that way but tis the world we live in i guess
Would you have any advice as to where i can get parts for it??? I found a couple places over the web that have small assortments but most everything in the form of gears and posi spools are "out of stock" or custom order at 2-3 times the price of regular GM stuff...
strength wise i hear they're comparable to the 8.5 gm 10 bolt which would suit my application however i'd prefer something on the lines of 3.42 gears with a posi instead of whats in it now...also looks like i may need to change axles too if i go that route because with different series carriers the axle spline count chages aswell on these type "0's" right? any ideas?
thanks for you time
Zack
thanks for you time
Zack
12 bolt Olds
thanks for you time
Zack
thanks for you time
Zack
588 4 series carrier is 28 spline and hold FACTORY 3.42-5.00
The aftermarket gears from what was RICHMOND gears all mount on the 3 series carrier which is ONLY 28 spline in the factory carrier 671 casting
We carry both 28 and 31 spline carriers for the 3 series carrier and aftermarket gears.
Jim
JD
Axle spline is fine as is 28 you can upgrade to 31 BUT you DO NOT have to. 672 carrier is the 4 series and holds FACTORY 3.42-5.00 gear sets
Jim
JD
Jim
JD
Wow that helps thank you! Do you have a website or any way i can contact you and/or view you product line?
Zack
Nevermind i found it, will be in touch...thanks again
J D RAce
www.jdrace.com
Only problem is this was suppose to be completed 2-3 year ago. Family matter. Nephew hit college ...Then Girl friend happened. NOW maybe marriage. lol.
I have more business i can deal with right now and i am afraid if i do open the store THERE will be more than I can deal with at one time. Good yes BUT I do not want to get sloppy with building etc.
So you can always contact me there register on the form for all differential set -up help etc. If you have the time I have the time. Jim
J D
J D
L77F85
Drivetrain/Differentials
16
November 29th, 2013 06:19 AM
81 regency
April 21st, 2011 06:18 PM
1BAD68"S"
December 29th, 2007 09:05 PM
